Apple 16-inch MacBook Pro: Apple M1 Max 1TB Space Grey
Quicklinx: GK0PWS00 Mfr#: MK1A3B/A
  • IEEE 802.11n
With the blazing-fast M1 Max chip - the first Apple silicon designed for pros - you get groundbreaking performance and amazing battery life. Add to that a stunning Liquid Retina XDR display, the amazing camera and audio, and all the ports you need. The first notebook of its kind, this MacBook Pro is a beast.
  • Scary faster
    M1 Max delivers two times faster graphics processing and double the memory bandwidth of M1 Pro. And it has a dedicated media engine for decode and two for encode - with up to two times faster video encoding - and two ProRes accelerators for even higher multistream performance.
  • You can do this all day
    Ferocious performance with game-changing battery life - that efficiency is the magic of Apple silicon. MacBook Pro delivers the same amazing performance whether it's plugged in or not.
  • The coolest part
    Advanced thermal systems move 50 percent more air, even at lower fan speeds. And thanks to the efficiency of Apple silicon, the fans never turn on for many tasks you do every day.
  • Liquid Retina XDR
    It features Extreme Dynamic Range and a million to one contrast ratio. HDR content comes to life in photos, video, and games - with refined specular highlights, incredible detail in shadows, and vibrant, true-to-life colors. Each display is factory calibrated and features pro reference modes for HDR color grading, photography, design, and print production.
  • ProMotion
    ProMotion comes to Mac for the first time, making everything from scrolling through a web page to gaming super fluid and responsive - while also reducing power consumption. With refresh rates of up to 120Hz, the adaptive technology automatically adjusts to match the movement of the content. ProMotion video editors can also choose a fixed refresh rate that precisely aligns with their footage.
  • Heads up - the camera's 1080p HD
    Staying connected is more important than ever. That's why the MacBook Pro camera has double the resolution - 1080p - and uses a lens with a wider aperture that lets in more light. Together with a larger image sensor that has more efficient pixels, the camera delivers two times better low-light performance.
  • Three studio-quality mics
    Thanks to mics with an up to 60 percent lower noise floor, MacBook Pro can capture even the subtlest sounds. And the three-mic array uses directional beamforming so your voice always comes through loud and clear.
  • Six-speaker sound system
    Four force-canceling woofers reveal notes up to a half-octave deeper and fill the room with up to 80 percent more bass. And the high-performance tweeters project clearer, fuller vocals.
  • Spatial audio
    Thanks to the room-filling six-speaker system and advanced algorithms, MacBook Pro supports spatial audio when playing music or video with Dolby Atmos, creating a sophisticated, three-dimensional soundstage. Combine that with the Liquid Retina XDR display, and it's like having a portable theater.
  • More plugged in than ever
    Transfer photos and videos with an SDXC card reader. Connect to TVs or displays with HDMI output. Listen using a 3.5 mm headphone jack that detects and automatically adjusts for high-impedance headphones. Connect to high-speed peripherals or displays with three Thunderbolt 4 ports. And fast-charge using the quick-releasing MagSafe 3 port.
  • More pixels than ever
    Connect up to three Pro Display XDRs and a 4K TV with M1 Max. Or connect up to two Pro Display XDRs with M1 Pro.
  • Pro power meets pro keyboard
    For the first time, Magic Keyboard brings a full-height function key row to MacBook Pro - with the tactile feel of mechanical keys that pros love. It includes keyboard shortcuts for Spotlight, Siri, Dictation, and Do Not Disturb. And Touch ID has a tactile ring that guides your finger for a fast, easy, secure way to unlock your Mac.
Apple MacBook Pro - 16.2" - Apple M1 Max - 32 GB RAM - 1 TB SSD - UK
Notebook
Operating System
macOS Monterey 12.0
Apple M1 Max
32 GB (unified memory)
Storage
1 TB SSD
Display
16.2" Mini LED backlight 3456 x 2234 @ 120 Hz - 254 ppi
Graphics
Apple M1 Max 32-core
Input Device
Force Touch trackpad
Keyboard
Keyboard Backlight
Integrated Webcam
Bluetooth 5.0, 802.11a/b/g/n/ac/ax
Up to 21 hours
Ambient light sensor
Security
Fingerprint reader
Space grey
35.57 cm x 24.81 cm x 1.68 cm
2.2 kg
Environmental Standards
ENERGY STAR Qualified
Limited warranty - 1 year , Technical support - phone consulting - 90 days
Notebook
Operating System
Apple macOS Monterey 12.0
Processor / Chipset
CPU
Apple M1 Max
Number of Cores
10-core
RAM
Storage
Main Storage
1 TB SSD soldered
Display
16.2"
LCD Backlight Technology
Mini LED backlight
Resolution
3456 x 2234
V-Sync Rate at Max Res.
120 Hz
Widescreen
Pixel Density (ppi)
254
Image Brightness
1000 cd/m²
Colour Support
1 billion colours
BFR/PVC-free, Mercury free, beryllium free, arsenic free, ProMotion technology, Liquid Retina display, P3 Wide Color Gamut, Extreme Dynamic Range (XDR), True Tone technology, 1600 cd/m² peak brightness (HDR)
Keyboard Name
Magic Keyboard
Audio & Video
Graphics Processor
Max Monitors Supported
4 external monitor(s)
Video System Features
Hardware-accelerated H.264, HEVC, ProRes and ProRes RAW, two ProRes encode and decode engines, video decode engine, two video encode engines
Camera
Yes - 1080p
Camera Features
Advanced image signal processor (ISP), FaceTime 1080p HD camera
Sound
Six speakers, three microphones
Dolby Atmos
Input
Keyboard, Force Touch trackpad
Keyboard Backlight
Keyboard Layout
Pressure sensitivity, multi-touch touchpad, Multi-Touch Gesture Recognition, ambient light sensor, force click, Touch ID sensor
Communications
Wireless
Lithium polymer
100 Wh
Run Time
Up to 21 hours
Battery Run Time
Video playback: up to 21 hours , Web browsing: up to 14 hours
AC Adapter
Input
AC 100-240 V (50/60 Hz)
Output
140 Watt
Connections & Expansion
Interfaces Details
3 x USB4 (supports Thunderbolt 4, DisplayPort Alt Mode) , Headphone output , HDMI
Memory Card Reader
Yes (SDXC Card)
Software
Software Included
Apple QuickTime, Apple iMovie, Apple Safari, Apple GarageBand, Photo Booth, Apple Time Machine, Apple FaceTime, Apple Preview, Mail, Maps, Photos, Reminders, App Store, Music, Contacts, Stocks, Notes, Calendar, Siri, Messages, Dictation, Apple iBooks, Apple Keynote, Apple Pages, Apple Numbers, News, Voice Memos, Podcasts, Home, Apple TV, Find My, Apple Pay
Space grey
Case Material
Aluminum
Integrated Options
Security
Fingerprint reader
VoiceOver screen reader, Voice Control
USB-C power adapter
Localization
2.2 kg
Sustainability Information
TCO Certified
ENERGY STAR Certified
10 °C
35 °C
0 - 90% (non-condensing)
GK0P Apple USB-C Woven Charge Cable (1m) In Stock £21.19
