Apple 15-inch MacBook Pro with Touch Bar: 2.2GHz 6-Core i7 256GB - Space Grey
Quicklinx: DPBGWS00 Mfr#: MR932B/A
  • Core i7
  • IEEE 802.11n
More power. More performance. More pro.
  • New eighth-generation Intel 6-core and quad-core processors.
  • Up to 32GB of memory for running multiple pro apps.
  • Stunning Retina display with True Tone technology.
  • Touch Bar for working more productively.
With great power comes great capability.
MacBook Pro elevates the notebook to a whole new level of performance and portability. Wherever your ideas take you, you’ll get there faster than ever with high-performance processors and memory, advanced graphics, amazingly fast storage and more.
More power at its cores.
With eighth-generation Intel Core processors, MacBook Pro reaches new heights in compute performance. The 15-inch model now features a 6-core Intel Core processor that works up to 70 per cent faster than the previous generation, enabling up to 4.8GHz Turbo Boost speeds. And a quad-core processor on the 13-inch MacBook Pro with Touch Bar now makes it up to twice as fast as the previous generation. So when you’re powering through pro-level processing jobs like compiling code, rendering 3D models, adding special effects, layering multiple tracks or encoding video, you’ll get everything done. Faster.
Eye-opening graphics performance.
MacBook Pro features a Radeon Pro discrete GPU in every 15-inch model, combining impressive power with remarkable power efficiency. And now we’ve paired each discrete GPU with 4GB of GDDR5 memory as standard, giving you fluid, real-time performance for pro tasks like rendering 3D titles in Final Cut Pro X. The 13-inch model with Touch Bar features powerful integrated graphics with 128MB of embedded DRAM — twice as much as the previous generation — which accelerates graphics tasks. That means more time for what matters most — creating amazing work.
  • Eye-opening graphics performance
    MacBook Pro features a fast GPU, combining impressive power with remarkable power efficiency. That means more time for what matters most - creating amazing work.
  • Make quicker work of everything
    MacBook Pro includes a drive that's blazing fast, and has enough space to take even your big files with you, like large photo libraries or video projects. So you can boot up, launch multiple apps, or import huge files in a flash.
  • Powerful and versatile port
    Thunderbolt 3 combines ultra-high bandwidth with the versatility of the USB-C to create one revved-up universal port. It integrates data transfer, charging, and video output in a single connector.
  • Music to your ears
    MacBook Pro has beautifully balanced, high-fidelity sound that takes listening to other levels with wide dynamic range and more bass for maximum boom. And the speakers are connected directly to system power, enabling greater peak amplification. So you can mix a track on the fly, edit video on location, or enjoy a movie on the go.
Apple MacBook Pro with Touch Bar - 15.4" - Intel Core i7 - - 16 GB RAM - 256 GB SSD - UK
Notebook
Operating System
macOS Catalina 10.15
Intel Core i7 (8th Gen) - 2.2 GHz (4.1 GHz) / 9 MB Cache
16 GB DDR4 (provided memory is soldered)
Storage
256 GB SSD
Display
15.4" LED backlight 2880 x 1800 / WQXGA+ - 220 ppi
Graphics
AMD Radeon Pro 555X / Intel UHD Graphics 630
Video Memory
4 GB GDDR5 SDRAM
Input Device
Force Touch trackpad, Touch Bar
Keyboard
Keyboard Backlight
Integrated Webcam
802.11a/b/g/n/ac, Bluetooth 5.0
Up to 10 hours
Security
Fingerprint reader
Space grey
34.93 cm x 24.07 cm x 1.55 cm
1.83 kg
Environmental Standards
ENERGY STAR Qualified
SAR
0.44 W/kg (body)
Limited warranty - 1 year , Technical support - phone consulting - 90 days
Notebook
Operating System
Apple macOS Catalina 10.15
Processor / Chipset
CPU
Intel Core i7 (8th Gen) 2.2 GHz
Max Turbo Speed
4.1 GHz
Number of Cores
6-core
Cache
L3 - 9 MB
64-bit Computing
Intel Turbo Boost Technology
RAM
16 GB (provided memory is soldered)
DDR4 SDRAM
Speed
2400 MHz
Storage
Main Storage
256 GB SSD soldered
Display
15.4" - IPS
LCD Backlight Technology
LED backlight
Resolution
2880 x 1800 (WQXGA+)
Widescreen
Pixel Density (ppi)
220
Image Brightness
500 cd/m²
BFR/PVC-free, Mercury free, Wide Colour Gamut, arsenic-free glass, beryllium free, Retina display, True Tone display
Audio & Video
Multi-GPU Configuration
1 single GPU card / integrated GPU
Graphics Processor
Video Memory
4 GB GDDR5 SDRAM
Camera
Yes - 720p
Camera Features
FaceTime HD camera
Sound
Stereo speakers, three microphones
Input
Keyboard, Force Touch trackpad, Touch Bar
Keyboard Backlight
Keyboard Layout
Pressure sensitivity, multi-touch touchpad, Multi-Touch Gesture Recognition, ambient light sensor, force click, Touch ID sensor
Communications
Wireless
Lithium polymer
83.6 Wh
Run Time
Up to 10 hours
Battery Run Time
Web browsing over Wi-Fi: up to 10 hours , Video playback: up to 10 hours , Standby time: up to 30 days
AC Adapter
Input
AC 100-240 V (50/60 Hz)
Output
87 Watt
Connections & Expansion
4 x USB-C 3.1 Gen 2 (supports Thunderbolt 3, DisplayPort Alt Mode) (Power Delivery) , Headphone output
Software
Software Included
Drivers & Utilities, Apple QuickTime, Apple iTunes, Apple Mac OS X Mail, Apple Mac OS X Chess, Apple iMovie, Apple DVD Player, Apple Safari, Apple GarageBand, Apple Dashboard, Photo Booth, Apple Time Machine, Apple Mac App Store, Apple FaceTime, Apple Automator, Apple Launchpad, Apple Mission Control, Apple Preview, Apple Calculator, Apple Dictionary, Apple Image Capture, Apple Stickies, Apple TextEdit, Apple System Preferences, Maps, Reminders, Contacts, Notes, Calendar, Apple AirDrop, Siri, Notification Center, Messages, Dictation, iCloud, Game Center, Apple AirPlay, Apple Font Book, Apple iBooks, Apple Keynote, Apple Pages, Apple Numbers
Space grey
Case Material
Aluminum
Security
Fingerprint reader
USB-C power adapter
USB-C charge cable
SAR Value
0.44 W/kg (body)
Localization
1.83 kg
Sustainability Information
ENERGY STAR Certified
10 °C
35 °C
0 - 90% (non-condensing)
