MacBook Pro elevates the notebook to a whole new level of performance and portability. Wherever your ideas take you, you'll get there faster than ever with a high-performance processor and memory, advanced graphics, blazing-fast storage, and more - all in a compact package.
More power at its cores
With an advanced processor, the 13-inch MacBook Pro is ready to take on even the toughest tasks. So when you're powering through pro-level processing jobs like compiling code, layering multiple tracks in a music composition, or encoding video, you'll get everything done faster. -
Magic Keyboard: a powerful arrangement
The 13-inch MacBook Pro is designed to let you do everything faster and more efficiently. The Magic Keyboard features a refined scissor mechanism with 1 mm of travel, delivering great typing experience. A dedicated Escape key allows quick switching between modes and views. The inverted-T arrow keys help you fly through lines of code, spreadsheets, or game environments. The Touch Bar puts powerful shortcuts front and center, and Touch ID provides fast authentication. -
Apple T2 Security Chip: the next generation of security
Every MacBook Pro is equipped with the Apple T2 Security Chip - the second-generation custom Mac silicon designed to make everything you do even more secure. It includes a Secure Enclave coprocessor that provides the foundation for secure boot and encrypted storage capabilities. It also consolidates many discrete controllers, including the system management controller, audio controller, and SSD controller, into one. -
Easy on the eyes, music to your ears
The Retina display features bright LED backlighting and delivers deep blacks and bright whites. It supports P3 wide color for even more vibrant greens and reds than with sRGB. And every MacBook Pro features True Tone technology. The white balance automatically adjusts to match the color temperature of the light around you - for a more natural viewing experience. MacBook Pro has a dynamic soundstage that feels and sounds much wider than its physical dimensions imply. Movies are more immersive. Music more room-filling. And three built-in mics form directional beams that capture your voice more clearly for FaceTime calls and talking to Siri. -
Thunderbolt 3: powerful and versatile port
Thunderbolt 3 combines ultra-high bandwidth with the ultra-versatility of the USB-C industry standard to create one revved-up universal port. It integrates data transfer, charging, and video output in a single connector, delivering up to 40Gb/s of throughput for twice the bandwidth of Thunderbolt 2. MacBook Pro is available with up to four ports, so you can do all of that from either side. Existing devices are easily connected with a cable or adapter. And Thunderbolt 3 is reversible, so no matter how you plug in, it's always right side up.
- Apple MacBook Pro with Touch Bar - 13.3" - Intel Core i5 - - 16 GB RAM - 512 GB SSD - UK
- Product Type
- Notebook
- Operating System
- macOS Catalina 10.15
- Processor
- Intel Core i5 (10th Gen) - 2 GHz (3.8 GHz) / 6 MB Cache
- Memory
- 16 GB LPDDR4X (provided memory is soldered)
- Storage
- 512 GB SSD
- Display
- 13.3" LED backlight 2560 x 1600 / WQXGA @ 60 Hz - 227 ppi
- Graphics
- Intel Iris Plus Graphics
- Input Device
- Force Touch trackpad, Touch Bar
- Keyboard
- UK
- Keyboard Backlight
- Integrated Webcam
- Networking
- 802.11a/b/g/n/ac, Bluetooth 5.0
- Battery
- Up to 10 hours
- Security
- Apple T2 Security Chip, fingerprint reader
- Silver
- 30.41 cm x 21.24 cm x 1.56 cm
- 1.4 kg
- Localisation
- Environmental Standards
- ENERGY STAR Qualified
- SAR
- 0.9 W/kg (body)
- Limited warranty - 1 year , Technical support - phone consulting - 90 days
- Product Type
- Notebook
- Operating System
- Apple macOS Catalina 10.15
Processor / Chipset
- CPU
- Intel Core i5 (10th Gen) 2 GHz
- Max Turbo Speed
- 3.8 GHz
- Number of Cores
- Quad-Core
- Cache
- L3 - 6 MB
- 64-bit Computing
- Intel Turbo Boost Technology
- RAM
- 16 GB (provided memory is soldered)
- Technology
- LPDDR4X SDRAM
- Speed
- 3733 MHz
Storage
- Main Storage
- 512 GB SSD soldered
Display
- 13.3" - IPS
- LCD Backlight Technology
- LED backlight
- Resolution
- 2560 x 1600 (WQXGA)
- V-Sync Rate at Max Res.
- 60 Hz
- Widescreen
- Pixel Density (ppi)
- 227
- Image Brightness
- 500 cd/m²
- BFR/PVC-free, Mercury free, arsenic-free glass, beryllium free, Retina display, True Tone display, P3 Wide Color Gamut
Audio & Video
- Graphics Processor
- Camera
- Yes - 720p
- Camera Features
- FaceTime HD camera
- Sound
- Stereo speakers, three microphones
- Dolby Atmos
Input
- Keyboard, Force Touch trackpad, Touch Bar
- Keyboard Layout
- UK
- Pressure sensitivity, multi-touch touchpad, Multi-Touch Gesture Recognition, ambient light sensor, force click, Touch ID sensor
Communications
- Wireless
- Technology
- Lithium polymer
- Capacity
- 58 Wh
- Run Time
- Up to 10 hours
- Battery Run Time
- Web browsing over Wi-Fi: up to 10 hours , Video playback: up to 10 hours , Standby time: up to 30 days
AC Adapter
- Input
- AC 100-240 V (50/60 Hz)
- Output
- 61 Watt
Connections & Expansion
- 4 x USB-C 3.1 Gen 2 (supports Thunderbolt 3, DisplayPort Alt Mode) (Power Delivery) , Headphone output
Software
- Software Included
- iTunes, Apple iMovie, Apple Safari, Apple GarageBand, Photo Booth, Apple Time Machine, Apple FaceTime, Apple Preview, Mail, Maps, Photos, Reminders, App Store, Contacts, Stocks, Notes, Calendar, Siri, Messages, Apple iBooks, Apple Keynote, Apple Pages, Apple Numbers, News, Voice Memos, Home
- Silver
- Case Material
- Aluminum
- Security
- Included Accessories
- USB-C power adapter
- Cables Included
- USB-C charge cable
- SAR Value
- 0.9 W/kg (body)
- Localization
- 1.4 kg
Sustainability Information
- ENERGY STAR Certified
- 10 °C
- 35 °C
- 0 - 90% (non-condensing)
