Apple 13-inch MacBook Pro with Touch Bar Core i5 512GB Silver
Quicklinx: FSY7WS00 Mfr#: MWP72B/A
Display Size: 13.3in
Operating System: Apple macOS Catalina 10.15
Installed Memory: 16GB
Hard Drive Capacity: 512GB
Optical Storage: None
  • Core i5
  • IEEE 802.11n
11 in stock
£1,374.17 ex VAT
£1,649.00 inc VAT
MacBook Pro elevates the notebook to a whole new level of performance and portability. Wherever your ideas take you, you'll get there faster than ever with a high-performance processor and memory, advanced graphics, blazing-fast storage, and more - all in a compact package.
  • More power at its cores
    With an advanced processor, the 13-inch MacBook Pro is ready to take on even the toughest tasks. So when you're powering through pro-level processing jobs like compiling code, layering multiple tracks in a music composition, or encoding video, you'll get everything done faster.
  • Magic Keyboard: a powerful arrangement
    The 13-inch MacBook Pro is designed to let you do everything faster and more efficiently. The Magic Keyboard features a refined scissor mechanism with 1 mm of travel, delivering great typing experience. A dedicated Escape key allows quick switching between modes and views. The inverted-T arrow keys help you fly through lines of code, spreadsheets, or game environments. The Touch Bar puts powerful shortcuts front and center, and Touch ID provides fast authentication.
  • Apple T2 Security Chip: the next generation of security
    Every MacBook Pro is equipped with the Apple T2 Security Chip - the second-generation custom Mac silicon designed to make everything you do even more secure. It includes a Secure Enclave coprocessor that provides the foundation for secure boot and encrypted storage capabilities. It also consolidates many discrete controllers, including the system management controller, audio controller, and SSD controller, into one.
  • Easy on the eyes, music to your ears
    The Retina display features bright LED backlighting and delivers deep blacks and bright whites. It supports P3 wide color for even more vibrant greens and reds than with sRGB. And every MacBook Pro features True Tone technology. The white balance automatically adjusts to match the color temperature of the light around you - for a more natural viewing experience. MacBook Pro has a dynamic soundstage that feels and sounds much wider than its physical dimensions imply. Movies are more immersive. Music more room-filling. And three built-in mics form directional beams that capture your voice more clearly for FaceTime calls and talking to Siri.
  • Thunderbolt 3: powerful and versatile port
    Thunderbolt 3 combines ultra-high bandwidth with the ultra-versatility of the USB-C industry standard to create one revved-up universal port. It integrates data transfer, charging, and video output in a single connector, delivering up to 40Gb/s of throughput for twice the bandwidth of Thunderbolt 2. MacBook Pro is available with up to four ports, so you can do all of that from either side. Existing devices are easily connected with a cable or adapter. And Thunderbolt 3 is reversible, so no matter how you plug in, it's always right side up.
Apple MacBook Pro with Touch Bar - 13.3" - Core i5 - 16 GB RAM - 512 GB SSD - UK
Notebook
Operating System
Intel Core i5 (10th Gen) 2 GHz (3.8 GHz) / 6 MB Cache
16 GB LPDDR4X (provided memory is soldered)
Storage
512 GB SSD
Optical Drive
No optical drive
Display
13.3" LED backlight 2560 x 1600 / WQXGA - 227 ppi
Graphics
Intel Iris Plus Graphics
Input Device
Force Touch trackpad, Touch Bar
Keyboard
Keyboard Backlight
Integrated Webcam
802.11a/b/g/n/ac, Bluetooth 5.0
Up to 10 hours
Security
Apple T2 Security Chip, fingerprint reader
Silver
30.41 cm x 21.24 cm x 1.56 cm
1.4 kg
Environmental Standards
ENERGY STAR Qualified
SAR
0.9 W/kg (body)
Limited warranty - 1 year , Technical support - phone consulting - 90 days
Notebook
Operating System
Processor / Chipset
CPU
Max Turbo Speed
3.8 GHz
Number of Cores
Quad-Core
Cache
L3 - 6 MB
64-bit Computing
Intel Turbo Boost Technology
RAM
16 GB (provided memory is soldered)
LPDDR4X SDRAM
Speed
3733 MHz
Storage
Main Storage
512 GB SSD - (soldered)
Display
13.3" - IPS
LCD Backlight Technology
LED backlight
Resolution
2560 x 1600 (WQXGA)
Widescreen
Pixel Density (ppi)
227
Image Brightness
500 cd/m²
Bezel Type
Flat front
BFR/PVC-free, Mercury free, arsenic-free glass, beryllium free, Retina display, True Tone display, 60 Hz refresh rate, P3 Wide Color Gamut
Audio & Video
Graphics Processor
Camera
Yes - 720p
Camera Features
FaceTime HD camera
Sound
Stereo speakers, three microphones
Dolby Atmos
Input
Keyboard, Force Touch trackpad, Touch Bar
Keyboard Backlight
Keyboard Layout
Pressure sensitivity, multi-touch touchpad, Multi-Touch Gesture Recognition, ambient light sensor, force click, Touch ID sensor
Communications
Wireless
Lithium polymer
58 Wh
Run Time
Up to 10 hours
Battery Run Time
Web browsing over Wi-Fi: up to 10 hours , Video playback: up to 10 hours , Standby time: up to 30 days
AC Adapter
Input
Output
61 Watt
Connections & Expansion
4 x USB-C 3.1 Gen 2/Thunderbolt 3/DisplayPort (Power Delivery) , Headphone output
Software
Software Included
iTunes, Apple iMovie, Apple Safari, Apple GarageBand, Photo Booth, Apple Time Machine, Apple FaceTime, Apple Preview, Mail, Maps, Photos, Reminders, App Store, Contacts, Stocks, Notes, Calendar, Siri, Messages, Apple iBooks, Apple Keynote, Apple Pages, Apple Numbers, News, Voice Memos, Home
Silver
Case Material
Aluminum
Security
USB-C power adapter
USB-C charge cable
SAR Value
0.9 W/kg (body)
Localization
1.4 kg
ENERGY STAR Certified
10 °C
35 °C
0 - 90% (non-condensing)
Graphics: Intel Iris Plus Graphics
Hard Drive Type: SSD
Brand: Apple
Price Range Ex VAT: 1000 - 1500
