Apple 13" MacBook Air: 1.6GHz Intel Core i5, 256GB -Silver
Quicklinx: DXHYWS00 Mfr#: MREC2B/A
  • Core i5
  • IEEE 802.11n
MacBook Air is designed to be powerful, capable, durable, and enjoyable to use. With enough battery life to get you through the day. That's the difference between a notebook that's simply thin and light and one that's so much more.
Multi-Touch technology is part of practically every Apple product. It's the best and most personal way to interact with your devices. And the optimal way to experience Multi-Touch on a notebook is through a trackpad. That's precisely the case with MacBook Air. The trackpad's spacious, all-glass surface doesn't have a button because the whole thing is the button. And with multi-touch gestures in OS X, you can interact with MacBook Air in ways that feel more intuitive and realistic than ever before.
MacBook Air features a unibody design for both the main enclosure and the display. Unibody construction means a higher-precision, less complex design with fewer parts. That translates to a notebook that's exceptionally thin and light, yet durable enough to handle the rigors of everyday use. In addition, MacBook Air offers innovations you won't find anywhere else.
  • Advanced technology from iPad
    A truly mobile device needs to be light, thin, and strong enough to take with you wherever you go. It also needs to perform quickly, spring to life instantly, and have enough battery power to keep up with you. It should have no spinning hard drive, no optical drive, and no unnecessary parts. All of that is true of iPad. And now, it's true of Apple's most mobile notebook ever: MacBook Air.
  • The best way to multi-touch on a notebook
    Multi-touch technology is simply the best and most personal way to interact with your software. And the optimal way to experience multi-touch on a notebook is through a trackpad. That's precisely the case with MacBook Air. Now you can perform more gestures than you have fingers on a spacious, all-glass surface that's smooth to the touch.
  • An incredible battery
    Removing the flash storage enclosure and placing the flash chips on the logic board freed up even more room. And voila: space for a bigger battery. And when you put MacBook Air to sleep for more than an hour, it enters what's called standby mode.
  • Unibody in unison
    When MacBook Air first debuted, it was groundbreaking in many ways. Chief among them was the precision unibody enclosure. Now that same engineering process comes to the MacBook Air display. Just like the main enclosure, the display housing is crafted from a single piece of aluminum, with all the structural elements machined directly into it. Total unibody construction means a less complex design with fewer parts. That makes MacBook Air exceptionally thin and light, yet still durable enough to handle the rigors of everyday use.
Apple MacBook Air with Retina display - 13.3" - Core i5 - 8 GB RAM - 256 GB SSD - UK
Notebook
Operating System
macOS Catalina 10.15
Intel Core i5 (8th Gen) 1.6 GHz (3.6 GHz) / 4 MB Cache
8 GB LPDDR3 (provided memory is soldered)
Storage
256 GB SSD
Optical Drive
No optical drive
Display
13.3" LED backlight 2560 x 1600 / WQXGA
Graphics
Intel UHD Graphics 617
Input Device
Force Touch trackpad
Keyboard
Keyboard Backlight
Integrated Webcam
802.11a/b/g/n/ac, Bluetooth 4.2
Up to 12 hours
Security
Fingerprint reader
Silver
30.41 cm x 21.24 cm x 1.56 cm
1.25 kg
Environmental Standards
ENERGY STAR Qualified
Limited warranty - 1 year , Technical support - phone consulting - 90 days
Notebook
Operating System
Apple macOS Catalina 10.15
Processor / Chipset
CPU
Max Turbo Speed
3.6 GHz
Number of Cores
Dual-Core
Cache
L3 - 4 MB
64-bit Computing
Intel Turbo Boost Technology
RAM
8 GB (provided memory is soldered)
Max RAM Supported
16 GB
LPDDR3 SDRAM
Speed
2133 MHz
Storage
Main Storage
256 GB SSD - (soldered) PCIe
Display
13.3" - IPS
LCD Backlight Technology
LED backlight
Resolution
2560 x 1600 (WQXGA)
Widescreen
Image Aspect Ratio
16:10
BFR/PVC-free, Mercury free, beryllium free, arsenic free, 227 ppi
Audio & Video
Graphics Processor
Camera
Yes - 720p
Camera Features
FaceTime HD camera
Sound
Stereo speakers, three microphones
Input
Keyboard, Force Touch trackpad
Keyboard Backlight
Keyboard Layout
Pressure sensitivity, multi-touch touchpad, Multi-Touch Gesture Recognition, ambient light sensor, force click, Touch ID sensor
Communications
Wireless
Lithium polymer
50.3 Wh
Run Time
Up to 12 hours
Battery Run Time
Web browsing over Wi-Fi: up to 12 hours , Video playback: up to 13 hours , Standby time: up to 30 days
AC Adapter
Input
Output
30 Watt
Connections & Expansion
2 x USB-C 3.1 Gen 2/Thunderbolt 3/DisplayPort (Power Delivery) , Headphone output
Software
Software Included
iTunes, Apple iMovie, Apple Safari, Apple GarageBand, Photo Booth, Apple Time Machine, Apple FaceTime, Apple Preview, Mail, Maps, Photos, Reminders, App Store, Contacts, Stocks, Notes, Calendar, Siri, Messages, Apple iBooks, Apple Keynote, Apple Pages, Apple Numbers, News, Voice Memos, Home
Silver
Case Material
Aluminum
Security
Fingerprint reader
T2 Security Chip
USB-C power adapter
USB-C charge cable
Localization
1.25 kg
ENERGY STAR Certified
10 °C
35 °C
0 - 90% (non-condensing)
