Product
Apple 12-inch MacBook: 1.3GHz dual-core Intel Core i5 512GB - Gold
Quicklinx: DXHHWS00 Mfr#: MRQP2B/A
Display Size: 12in
Operating System: Apple macOS Mojave 10.14
Installed Memory: 8GB, 8GB
Hard Drive Capacity: 512GB
Optical Storage: None
  • Core i5
  • IEEE 802.11n
More than 50 in stock
£1,290.83 ex VAT
£1,548.99 inc VAT
From daily tasks like launching apps and opening files to more advanced computing, you can power through your day thanks to faster SSDs and fast processing power.
  • Incredibly thin and light
    Each component inside MacBook has been meticulously designed to get the most out of an incredibly thin and light enclosure.
  • Fanless architecture
    MacBook was built for virtually silent performance. Its processor runs on low power, which generates less heat and eliminates the need for a fan to cool the computer. Instead, the logic board is seated on an anisotropic graphite sheet that helps disperse any heat.
  • A keyboard refined for an even better hands-on experience
    To fit a comfortable keyboard into MacBook, Apple designed a keyboard from the ground up - including each key and its underlying mechanism. This makes the whole keyboard not only much thinner, but also more comfortable and precise, so your fingers feel right at home.
  • Precise control at your fingertips
    Multi-touch gestures make it easy and intuitive to interact with your MacBook. Scroll in any direction, swipe through web pages, pinch, rotate, or click to unlock other useful capabilities.
  • Connect to everything you love
    With powerful technologies in an incredibly compact enclosure, MacBook is designed to fit perfectly into a world where just about anything you do with a notebook can be done over the air. For those moments when you do need to plug in, USB-C packs a ton of capability into one small and convenient port.
Apple MacBook - 12" - Core i5 - 8 GB RAM - 512 GB SSD - English
Notebook
Operating System
Intel Core i5 (7th Gen) 1.3 GHz (3.2 GHz) / 4 MB Cache
8 GB LPDDR3 (provided memory is soldered)
Storage
512 GB - soldered SSD
Optical Drive
No optical drive
Display
12" LED backlight 2304 x 1440
Graphics
Intel HD Graphics 615
Input Device
Force Touch trackpad
Keyboard Backlight
Integrated Webcam
802.11a/b/g/n/ac, Bluetooth 4.2
Up to 12 hours
Gold
28.05 cm x 19.65 cm x 1.31 cm
920 g
Environmental Standards
ENERGY STAR Qualified
Limited warranty - 1 year , Technical support - phone consulting - 90 days
Notebook
Operating System
Processor / Chipset
CPU
Max Turbo Speed
3.2 GHz
Number of Cores
Dual-Core
Cache
L3 - 4 MB
64-bit Computing
Intel Turbo Boost Technology 2.0
RAM
8 GB (provided memory is soldered)
LPDDR3 SDRAM
Speed
1866 MHz
Storage
Main Storage
512 GB SSD - (soldered) PCIe
Display
12" - IPS
LCD Backlight Technology
LED backlight
Resolution
2304 x 1440
Widescreen
Image Aspect Ratio
16:10
BFR/PVC-free, Mercury free, 226 ppi, arsenic-free glass, beryllium free, 178° horizontal and vertical viewing angle
Audio & Video
Graphics Processor
Camera
Yes - 480p
Sound
Stereo speakers, two microphones
Input
Keyboard, Force Touch trackpad
Keyboard Backlight
Keyboard Layout
English
Pressure sensitivity, multi-touch touchpad, Multi-Touch Gesture Recognition, ambient light sensor, force click, 12 function keys
Communications
Wireless
Lithium polymer
41.4 Wh
Run Time
Up to 12 hours
Battery Run Time
Web browsing over Wi-Fi: up to 10 hours , Video playback: up to 12 hours , Standby time: up to 30 days
AC Adapter
Input
Output
30 Watt
Connections & Expansion
USB-C 3.1 Gen 1/DisplayPort 1.2 , Headphone output
Software
Software Included
Drivers & Utilities, Apple QuickTime, Apple iTunes, Apple iMovie, Apple Safari, Apple GarageBand, Apple Dashboard, Photo Booth, Apple Time Machine, Apple FaceTime, Apple Automator, Apple Launchpad, Apple Mission Control, Apple Preview, Apple Calculator, Apple Dictionary, Apple Image Capture, Apple Stickies, Apple TextEdit, Apple System Preferences, Mail, Maps, Photos, Reminders, App Store, Contacts, Notes, Calendar, Apple AirDrop, Siri, Notification Center, Messages, Dictation, iCloud, Game Center, Apple AirPlay, Apple Font Book, Apple iBooks, Apple Keynote, Apple Pages, Apple Numbers
Gold
Case Material
Aluminum
USB-C power adapter
USB-C charge cable
Localization
920 g
ENERGY STAR Certified
10 °C
35 °C
0 - 90% (non-condensing)
Software applications
Apple 12-inch MacBook: 1.3GHz dual-core Intel Core i5 512GB - Gold Bundle deal on Apple 12-inch MacBook: 1.3GHz dual-core Intel Core i5 512GB - Gold
£1,474.55
saving £8.33
£1,390.59
Display Size: 12in
Graphics: Intel HD Graphics 615
Hard Drive Type: SSD
Brand: Apple
Price Range Ex VAT: 1000 - 1500
