From daily tasks like launching apps and opening files to more advanced computing, you can power through your day thanks to faster SSDs and fast processing power.
Incredibly thin and light
Each component inside MacBook has been meticulously designed to get the most out of an incredibly thin and light enclosure. -
Fanless architecture
MacBook was built for virtually silent performance. Its processor runs on low power, which generates less heat and eliminates the need for a fan to cool the computer. Instead, the logic board is seated on an anisotropic graphite sheet that helps disperse any heat. -
A keyboard refined for an even better hands-on experience
To fit a comfortable keyboard into MacBook, Apple designed a keyboard from the ground up - including each key and its underlying mechanism. This makes the whole keyboard not only much thinner, but also more comfortable and precise, so your fingers feel right at home. -
Precise control at your fingertips
Multi-touch gestures make it easy and intuitive to interact with your MacBook. Scroll in any direction, swipe through web pages, pinch, rotate, or click to unlock other useful capabilities. -
Connect to everything you love
With powerful technologies in an incredibly compact enclosure, MacBook is designed to fit perfectly into a world where just about anything you do with a notebook can be done over the air. For those moments when you do need to plug in, USB-C packs a ton of capability into one small and convenient port.
- Apple MacBook - 12" - Core i5 - 8 GB RAM - 512 GB SSD - English
- Product Type
- Notebook
- Operating System
- Apple macOS Mojave 10.14
- Processor
- Intel Core i5 (7th Gen) 1.3 GHz (3.2 GHz) / 4 MB Cache
- Memory
- 8 GB LPDDR3 (provided memory is soldered)
- Storage
- 512 GB - soldered SSD
- Optical Drive
- No optical drive
- Display
- 12" LED backlight 2304 x 1440
- Graphics
- Intel HD Graphics 615
- Input Device
- Force Touch trackpad
- Keyboard Backlight
- Integrated Webcam
- Networking
- 802.11a/b/g/n/ac, Bluetooth 4.2
- Battery
- Up to 12 hours
- Gold
- 28.05 cm x 19.65 cm x 1.31 cm
- 920 g
- Localisation
- Environmental Standards
- ENERGY STAR Qualified
- Limited warranty - 1 year , Technical support - phone consulting - 90 days
- Product Type
- Notebook
- Operating System
Processor / Chipset
- CPU
- Max Turbo Speed
- 3.2 GHz
- Number of Cores
- Dual-Core
- Cache
- L3 - 4 MB
- 64-bit Computing
- Intel Turbo Boost Technology 2.0
- RAM
- 8 GB (provided memory is soldered)
- Technology
- LPDDR3 SDRAM
- Speed
- 1866 MHz
Storage
- Main Storage
- 512 GB SSD - (soldered) PCIe
Display
- 12" - IPS
- LCD Backlight Technology
- LED backlight
- Resolution
- 2304 x 1440
- Widescreen
- Image Aspect Ratio
- 16:10
- BFR/PVC-free, Mercury free, 226 ppi, arsenic-free glass, beryllium free, 178° horizontal and vertical viewing angle
Audio & Video
- Graphics Processor
- Camera
- Yes - 480p
- Sound
- Stereo speakers, two microphones
Input
- Keyboard, Force Touch trackpad
- Keyboard Layout
- English
- Pressure sensitivity, multi-touch touchpad, Multi-Touch Gesture Recognition, ambient light sensor, force click, 12 function keys
Communications
- Wireless
- Technology
- Lithium polymer
- Capacity
- 41.4 Wh
- Run Time
- Up to 12 hours
- Battery Run Time
- Web browsing over Wi-Fi: up to 10 hours , Video playback: up to 12 hours , Standby time: up to 30 days
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 30 Watt
Connections & Expansion
- USB-C 3.1 Gen 1/DisplayPort 1.2 , Headphone output
Software
- Software Included
- Drivers & Utilities, Apple QuickTime, Apple iTunes, Apple iMovie, Apple Safari, Apple GarageBand, Apple Dashboard, Photo Booth, Apple Time Machine, Apple FaceTime, Apple Automator, Apple Launchpad, Apple Mission Control, Apple Preview, Apple Calculator, Apple Dictionary, Apple Image Capture, Apple Stickies, Apple TextEdit, Apple System Preferences, Mail, Maps, Photos, Reminders, App Store, Contacts, Notes, Calendar, Apple AirDrop, Siri, Notification Center, Messages, Dictation, iCloud, Game Center, Apple AirPlay, Apple Font Book, Apple iBooks, Apple Keynote, Apple Pages, Apple Numbers
- Gold
- Case Material
- Aluminum
- Included Accessories
- USB-C power adapter
- Cables Included
- USB-C charge cable
- Localization
- 920 g
- ENERGY STAR Certified
- 10 °C
- 35 °C
- 0 - 90% (non-condensing)
Software applications
Bundle includes:
Microsoft Office Home & Business 2019 (Medialess, 1 PC, One Time Purchase) worth £192.05 | in stock |
£1,474.55
saving £8.33
saving £8.33
Bundle includes:
Microsoft Office 365 Business Premium ‘in a box’ 1 year subscription/license worth £99.76 | in stock |
£1,390.59
