Apple 12.9-inch iPad Pro Wi-Fi + Cellular 256GB - Space Grey
CONTACT OUR IT SPECIALISTS TO ENQUIRE ABOUT EDUCATION PRICING!
Quicklinx: CY8TWS00 Mfr#: MPA42B/A
Colours:
To create an iPad this huge, no detail was too small. From the way images are brought to life to its considerable versatility, it was pushed every aspect of what's possible with iPad to advanced heights. The end result, unmistakable the moment you begin using it, goes beyond a larger display. Unlike anything before it, iPad Pro is a far bigger experience.
  • M2 chip
    M2 turbocharges machine learning with a faster Neural Engine and has extra memory-ordinary power that brings unprecedented performance and capabilities to the iPad Pro. You'll be able to create ultra-realistic 3D designs, build complex AR models, and immerse yourself in games with console graphics at even higher frame rates. And even when you throw yourself into such intense activities, you can count on a battery that lasts a full day.
  • Take video production into your own hands
    The M2 chip has a high-performance media engine that speeds up ProRes encoding and decoding-now conversion to this format is faster.
  • XDR Liquid Retina Display
    The Liquid Retina XDR display achieves an extraordinarily realistic level of definition. With excellent contrast, it's ideal for viewing and editing HDR photos and videos, and it's also perfect for enjoying movies and TV series. Its brightness is to die for. It comes standard with advanced technologies such as ProMotion, True Tone and the wide P3 color gamut. Plus you can use it in Reference mode, an essential aid for all jobs that require absolute color accuracy.
  • Zone-based brightness management
    The more than 10,000 mini-LEDs are grouped into more than 2,500 local dimming zones. The brightness of each is carefully adjusted according to what you're seeing, to achieve the incredible level of contrast. This ensures that even the most detailed HDR images and the most spectacular lighting effects, from explosions in action movies to panoramas of stars and galaxies, are rendered extremely accurately.
  • Front-facing camera
    iPad Pro has an ultra-wide-angle front-facing camera with a 12MP sensor and 122° field angle, ideal for taking photos and videos to post on social media. With the Auto Frame feature it always keeps you center stage in FaceTime calls, and there is also Portrait mode for taking beautiful selfies. It also works together with the TrueDepth camera to let you securely unlock your device with Face ID.
  • Automatic framing
    With ultra-wide-angle and machine learning, the Auto Frame feature frees you from your desk during video calls. Move around the room, and the frame will shift so you're never out of view. The lens also narrows the field or widens it as other people join you or leave during the call. And it also works with other developers' video conferencing apps, not just FaceTime. So you'll always be center stage.
  • Ultra-wide-angle
    The LiDAR scanner measures the time it takes light to reach an object and return, creating a depth map of the space you're in and making incredibly immersive AR experiences possible. Plus, it works with the powerful ISP processor to focus images and videos more accurately when there is little light, and reduce capture time.
  • Ultra-fast connections
    With ultrafast Wi-Fi and cellular connectivity, iPad has always been a champion of portability. And with Wi-Fi, you have the fastest wireless connection-everything goes like clockwork, even when sending large photos, files, and videos.
  • 5G
    With 5G compatibility, you can connect to the fastest networks to download or share files, watch movies, and work in teams wherever you are. Not only that, iPad Pro supports more bands than any other tablet, so you blaze through 5G in even more places.
Apple 12.9-inch iPad Pro Wi-Fi + Cellular - 2nd generation - tablet - 256 GB - 12.9" - 3G, 4G
Tablet
Display
12.9" IPS TFT - LED backlight - 2732 x 2048 (264 ppi) - Multi-Touch
Apple A10X Fusion (6-core) - 64-bit
Storage
256 GB
Cellular Technology
3G, 4G
Cellular Protocols
GSM, UMTS, EDGE, CDMA 2000 1X EV-DO Rev. A, HSPA, HSPA+, LTE, DC-HSDPA, CDMA 2000 1X EV-DO Rev. B, LTE Advanced
Wireless Connectivity
802.11a/b/g/n/ac, Bluetooth 4.2
Rear Camera
12 Megapixel focus: automatic
Front Camera
7 Megapixel
Navigation System
A-GPS/GLONASS
Security Devices
Fingerprint reader
Battery Run Time
Up to 10 hours
22.06 cm x 0.69 cm x 30.57 cm
692 g
Space grey
English / United Kingdom
0.97 W/kg (body)
1-year warranty
Tablet
Operating System
Apple iOS 12
Display
Resolution
Touchscreen
Multi-Touch
Anti-glare, anti-reflective, anti-fingerprint, Retina display, fully laminated display, True Tone display, ProMotion technology
Apple A10X Fusion
Number of Cores
6-core
64-bit Computing
Storage
256 GB
Communications
Cellular Technology
3G, 4G
Cellular Protocols
Band
GSM 850/900/1800/1900 / UMTS 850/900/1700/1900/2100 / CDMA 2000 X1 800/1900 / LTE 700/700 APT/700b/700c/700 de/800/ 800 DD/850/900/1500/1800/1900/TD 1900/2100/2300/TD 2300/TD 2500/2600/TD 2600/AWS
Rear Camera
Sensor Resolution
12 Megapixel
Camera Zoom
5x digital zoom
Focus Adjustment
Automatic
Lens Aperture
F/1.8
HDR Mode
Auto HDR mode
Face Detection
Body and face detection
Sapphire crystal lens cover, Focus Pixels, Cinematic video stabilisation, Live Photo, Playback zoom, Hybrid IR filter, Exposure control, noise reduction, geotagging
Front Camera
Sensor Resolution
7 Megapixel
Lens Aperture
F/2.2
FaceTime HD camera
Navigation System
Receiver
A-GPS/GLONASS
Multimedia
Supported Digital Audio Standards
WAV, AAC, AIFF, Audible, MP3, Apple Lossless, AC-3, HE-AAC, Audible AAX, Audible AAX+, protected AAC, EAC3, MP3 VBR
Supported Digital Video Standards
MPEG-4 SP (up to 640x480), Motion JPEG (up to 1280x720), H.264 High Profile Level 4.2 (up to 4K)
Audio
Two microphones, four speakers
Input Device
Security Devices
Fingerprint reader
Software
Preloaded Software
Clock, Mail, Notes, Calendar, Contacts, Messages, Camera, Files, FaceTime, Photo Booth, Safari, Photos, App Store, Maps, News, Find My iPhone, Stocks, Siri, Books, Reminders, Music, Find My Friends, Voice Memos, iTunes Store, Podcasts, Apple TV App, Home, Measure
System Requirements for PC Connection
Microsoft Windows 7 or later, Apple MacOS X 10.9.5 or later
Expansion and Connectivity
1 x headphones mini jack (3.5mm) , 1 x Lightning , 1 x Smart Connector
Lithium polymer
41 Wh
Run Time
Up to 10 hours
Run Time Details
Web browsing over Wi-Fi: up to 10 hour(s) , Video playback: up to 10 hour(s) , Audio playback: up to 10 hour(s) , Web browsing over cellular data network: up to 9 hour(s)
Space grey
Sensors
Accelerometer, ambient light sensor, 3-axis gyro sensor, digital compass, barometer
Charging via USB, VoiceOver screen reader, AirPrint, AirPlay, parental controls, Dictation, AssistiveTouch, MIMO technology, AirDrop, iBeacon microlocation, Family Sharing, Night Shift, Apple M10 motion coprocessor
Power adapter
Lightning to USB cable
0.97 W/kg (body)
22.06 cm
0.69 cm
30.57 cm
692 g
Limited warranty - 1 year , Technical support - phone consulting - 90 days
35 °C
5 - 95% (non-condensing)
Min Storage Temperature
-20 °C
Max Storage Temperature
45 °C
Max Altitude Operating
3 km
