Apple 12.9" iPad Pro Wi-Fi + Cellular 64GB Silver
CONTACT OUR IT SPECIALISTS TO ENQUIRE ABOUT EDUCATION PRICING!
Quicklinx: DZ6MWS00 Mfr#: MTHP2B/A
Operating System: Apple iOS 12
Processor: A12X Bionic
Screen Size: 12.9in
Capacity: 64GB
37 in stock
£932.50 ex VAT
£1,119.00 inc VAT
To create an iPad this huge, no detail was too small. From the way images are brought to life to its considerable versatility, it was pushed every aspect of what's possible with iPad to advanced heights. The end result, unmistakable the moment you begin using it, goes beyond a larger display. Unlike anything before it, iPad Pro is a far bigger experience.
  • Each and every one a thing of beauty
    iPad Pro has the advanced Retina display. The 12.9-inch screen offers more display area. Under the glass lie a revamped multi-touch subsystem and 5.6 million brilliant pixels, making it the high-resolution display. That extreme resolution, along with remarkably lifelike colors and deeper blacks, makes everything from photo editing to intense 3D games more vivid and deeply engaging.
  • A huge leap of engineering
    The Retina display on iPad Pro incorporates advanced technologies to enable unparalleled levels of precision and responsiveness. The multi-touch subsystem was designed to accommodate two types of touch - your finger and Apple pencil.
  • Photo alignment
    To improve on-axis contrast, it was used an advanced process called photo alignment. This involves shining UV light to create a uniform terrain across the film coating on the thin film transistor and color filter, so the display's liquid crystal molecules lie precisely where they should. Better-aligned molecules mean you see better contrast when looking directly at the display.
  • Variable refresh rate
    iPad Pro knows when the content on your screen is static and cuts the refresh rate in half. This means that the screen isn't just big, beautiful, and bright. It's also incredibly energy-efficient.
  • Timing controller
    The timing controller, or TCON, is the brains of the display. It tells each pixel what to do and when to do it. Since iPad Pro has 2.5 million more pixels, it was designed the TCON to handle the greater resolution, giving it more bandwidth to allow incredible pixel control at lightning-fast speeds.
  • An elegant form that's exceptionally strong
    iPad Pro feels reassuringly solid in the hand. The aluminum unibody is a perfect balance of lightness and uncommon strength.
  • Four speaker audio
    The iPad Pro has four advanced speakers that produce a stereo soundstage as enveloping as its display. For the first time, the speaker housings have been machined directly into the unibody enclosure. This architecture gives the speakers more back volume. You'll hear a wider frequency range and up to three times more output than on any other iPad.
  • An incredible sound experience, no matter how you turn it
    The speakers in iPad Pro aren't just high-fidelity, they're highly intelligent. While all four produce bass frequencies, the topmost speakers are dedicated to higher frequencies. They also automatically recognize whether the device is in portrait or landscape view. So you'll always get vivid, well-balanced sound no matter how you're holding iPad Pro.
  • The smart keyboard
    The advanced smart keyboard for iPad Pro has all the utility of an ordinary full-size keyboard, but its technology couldn't be less conventional. The surface is formed from a single sheet of custom-woven fabric that has been laser ablated to precisely form each key. This unique construction ensures a satisfyingly responsive, accurate, and natural feel. Underneath that fabric lies a conductive material that allows for a two-way flow of power and data. That's why you won't find any batteries, cords, or on/off switches on the smart keyboard. And unlike traditional wires, the conductive fabric can withstand a lifetime of folding, though it's nearly as thin as a sheet of paper.
  • More than a connector
    The smart connector is an interface that takes advantage of the two-way conductive fabric in the smart keyboard. It allows iPad Pro to provide power to the smart keyboard and lets the smart keyboard relay each of your keystrokes back to iPad Pro. Using the smart connector couldn't be easier. Simply align the smart keyboard to iPad Pro - just as you would with a smart cover - and start typing. There's even less distance between what's on your mind and what's on the display.
Apple 12.9-inch iPad Pro Wi-Fi + Cellular - 3rd generation - tablet - 64 GB - 12.9" - 3G, 4G
Tablet
Display
12.9" IPS TFT - LED backlight - 2732 x 2048 (264 ppi) - Multi-Touch
Apple A12X Bionic - 64-bit
Storage
64 GB
Cellular Technology
3G, 4G
Cellular Protocols
GSM, UMTS, EDGE, HSPA, HSPA+, LTE, DC-HSDPA, LTE Advanced
Wireless Connectivity
802.11a/b/g/n/ac, Bluetooth 5.0
Camera
12 Megapixel (rear), 7 Megapixel (front)
HD Video Recording
4K
Navigation System
A-GPS/Galileo/GLONASS/QZSS
Supported Text Formats
DOCX, PDF, TXT, RTF, DOC, HTML, XLS, XLSX, PPT, HTM
Supported Still Image Formats
GIF, TIFF, PPTX
Security Devices
Face ID
Battery Run Time
Up to 10 hours
21.49 cm x 0.59 cm x 28.06 cm
633 g
Silver
English / United Kingdom
1-year warranty
Tablet
Operating System
Apple iOS 12
Display
Resolution
Touchscreen
Multi-Touch
Image Brightness
600 cd/m²
Anti-reflective, fully laminated display, True Tone display, Wide colour display, ProMotion technology, fingerprint-resistant oleophobic coating, Liquid Retina display
Apple A12X Bionic
64-bit Computing
Storage
64 GB
Communications
Cellular Technology
3G, 4G
Cellular Protocols
Band
GSM 850/900/1800/1900 / UMTS 850/900/1700/1900/2100 / LTE 700 / 700 APT / 700b / 700c / 700de / 700 PS / 800 / 800 DD / 850 / 900 / 1500 / 1800 / 1900 / TD 1900 / TD 2000 / 2100 / 2300 / TD 2300 / TD 2500 / 2600 / TD 2600 / TD 3500 / AWS / AWS-3 / TD Unli
Camera
Resolution (MP)
Lens Aperture
F/1.8 (rear) / f/2.2 (front)
Digital Zoom
5
Frame Rate
60 frames per second
HD Video Recording
4K
Landscape/portrait mode, face detection, tap to focus, photo and video geotagging, autofocus, FaceTime HD camera, Burst mode, Slow motion video, noise reduction, sapphire crystal lens cover, backside illumination sensor, Continuous autofocus, Time-lapse mode, Focus Pixels, Cinematic video stabilisation, Panorama, 5-element lens, Hybrid IR filter, Timer mode, Exposure control, Auto image stabilisation, Live Photo, Playback zoom, 8MP still photos while recording 4K video, Retina Flash, Quad-LED True Tone flash, Smart HDR, Animoji, Memoji, Portrait Lighting, TrueDepth camera
EBook Reader
GIF, TIFF, PPTX
Navigation System
Receiver
Multimedia
Supported Digital Audio Standards
WAV, AAC, AIFF, Audible, MP3, Apple Lossless, AC-3, HE-AAC, protected AAC, EAC3, MP3 VBR
Supported Digital Video Standards
MPEG-4 SP (up to 640x480), Motion JPEG (up to 1280x720), H.264 High Profile Level 4.2 (up to 4K)
Audio
5 microphones, four speakers
Input Device
Security Devices
Face ID
Software
Preloaded Software
Clock, Mail, Notes, Calendar, Contacts, Messages, Camera, Files, FaceTime, Photo Booth, Safari, Photos, App Store, Maps, News, Find My iPhone, Stocks, Siri, Books, Reminders, Music, Find My Friends, Settings, Voice Memos, iTunes Store, Podcasts, Apple TV App, Home, Measure, Tips
System Requirements for PC Connection
Microsoft Windows 7 or later, Apple MacOS X 10.11.6 El Capitan or later
Expansion and Connectivity
1 x USB-C , 1 x Smart Connector , 1 x Magnetic connector
Lithium polymer
36.71 Wh
Run Time
Up to 10 hours
Run Time Details
Web browsing over Wi-Fi: up to 10 hour(s) , Video playback: up to 10 hour(s) , Audio playback: up to 10 hour(s) , Web browsing over cellular data network: up to 9 hour(s)
Silver
Sensors
Accelerometer, ambient light sensor, 3-axis gyro sensor, digital compass, barometer
VoiceOver screen reader, AirPlay, Dictation, AssistiveTouch, iBeacon microlocation, Apple M12 motion coprocessor, Neural Engine
Power adapter
USB-C charge cable - 1 m
21.49 cm
0.59 cm
28.06 cm
633 g
Limited warranty - 1 year , Technical support - phone consulting - 90 days
35 °C
5 - 95% (non-condensing)
Min Storage Temperature
-20 °C
Max Storage Temperature
45 °C
Max Altitude Operating
3 km
Apple 12.9 Bundle deal on Apple 12.9" iPad Pro Wi-Fi + Cellular 64GB Silver
£1,031.67
DZ6M Urban Armor Gear Metropolis Series for iPad Pro 12.9" (3rd Gen) - Black In Stock £49.99
Screen Size: 12.9in
Capacity: 64GB
Brand: Apple
Price Range Ex VAT: 750 - 1000
