The all-screen design means iPad Pro is a magical piece of glass that does everything you need, any way you hold it. With intuitive gestures, getting around is simple. The Liquid Retina display goes from edge to edge. True-to-life color and ProMotion technology make everything look gorgeous and feel responsive. Put all that power to work by multitasking with just a few swipes. Work on a creative project, message with a friend, search the web for inspiration, and make a FaceTime call. Faster graphics makes iPad Pro the perfect machine for augmented reality and a great way to play immersive games.
Apple Pencil now responds to your touch. With a double tap you can quickly change brushes or switch to the eraser, without interrupting your flow. And it attaches magnetically to pair and charge. The Smart Keyboard Folio provides a great typing experience and elegant front and back protection. USB-C gives you a high-performance connection to accessories like an external display or camera.
iPad Pro has two great cameras equipped with Smart HDR. The rear camera great for stunning photos, 4K video, document scanning, and AR experiences. And a TrueDepth camera perfect for portrait selfies, facetime, animoji, and memoji.
All-screen design
The all-screen design means iPad Pro is a magical piece of glass that does everything you need, any way you hold it. -
Intuitive gestures
With intuitive gestures, getting around is simple. -
The Liquid Retina display goes from edge to edge. True-to-life color and ProMotion technology make everything look gorgeous and feel responsive. -
Face ID
Face ID comes to iPad. It's engineered for secure unlocking and works seamlessly whether you hold it in portrait or landscape. Use Face ID to unlock your iPad Pro, log in to apps, and pay with a glance. -
Multitasking
Put all that power to work by multitasking with just a few swipes. Work on a creative project, message with a friend, search the web for inspiration, and make a FaceTime call. -
Faster graphics
Faster graphics makes iPad Pro the perfect machine for augmented reality and a great way to play immersive games. -
Apple Pencil responds to your touch
Apple Pencil now responds to your touch. With a double tap you can quickly change brushes or switch to the eraser, without interrupting your flow. And it attaches magnetically to pair and charge. -
The Smart Keyboard Folio provides a great typing experience and elegant front and back protection. -
USB-C
USB-C gives you a high-performance connection to accessories like an external display or camera. -
Two great cameras equipped with Smart HDR
- Apple 11-inch iPad Pro Wi-Fi - 1st generation - tablet - 512 GB - 11"
- Product Type
- Tablet
- Display
- 11" IPS TFT - LED backlight - 2388 x 1668 (264 ppi) - Multi-Touch
- Processor
- Apple A12X Bionic - 64-bit
- Storage
- 512 GB
- Wireless Connectivity
- 802.11a/b/g/n/ac, Bluetooth 5.0
- Rear Camera
- 12 Megapixel focus: automatic
- Front Camera
- 7 Megapixel
- Security Devices
- Face ID
- Battery Run Time
- Up to 10 hours
- 17.85 cm x 0.59 cm x 24.76 cm
- 468 g
- Space grey
- Localisation
- English / United Kingdom
- Specific Absorption Rate (SAR)
- 0.99 W/kg (body)
- 1-year warranty
- Product Type
- Tablet
- Operating System
- Apple iPadOS 14
Display
- Resolution
- Touchscreen
- Multi-Touch
- Image Brightness
- 600 cd/m²
- Anti-reflective, fully laminated display, True Tone display, Wide colour display, ProMotion technology, fingerprint-resistant oleophobic coating, Liquid Retina display
- Processor
- Apple A12X Bionic
- 64-bit Computing
- Storage
- 512 GB
Communications
Rear Camera
- Sensor Resolution
- 12 Megapixel
- Camera Zoom
- 5x digital zoom
- Focus Adjustment
- Automatic
- Lens Aperture
- F/1.8
- Face Detection
- Face detection
- Sapphire crystal lens cover, Cinematic video stabilisation, Focus Pixels, Cinematic video stabilisation, Live Photo, Playback zoom, Hybrid IR filter, Exposure control, noise reduction, geotagging
Front Camera
- Sensor Resolution
- 7 Megapixel
- Lens Aperture
- F/2.2
- FaceTime HD camera, Animoji, Memoji, TrueDepth camera
Multimedia
- Supported Digital Audio Standards
- WAV, AAC, AIFF, Audible, MP3, Apple Lossless, AC-3, HE-AAC, protected AAC, EAC3, MP3 VBR
- Supported Digital Video Standards
- MPEG-4 SP (up to 640x480), Motion JPEG (up to 1280x720), H.264 High Profile Level 4.2 (up to 4K)
- Audio
- 5 microphones, four speakers
Input Device
- Security Devices
- Face ID
Software
- Preloaded Software
- Clock, Mail, Notes, Calendar, Contacts, Messages, Camera, Files, FaceTime, Photo Booth, Safari, Photos, App Store, Maps, News, Find My iPhone, Stocks, Siri, Books, Reminders, Music, Find My Friends, Settings, Voice Memos, iTunes Store, Podcasts, Apple TV App, Home, Measure, Tips
System Requirements for PC Connection
- OS Required
- Microsoft Windows 7 or later, Apple MacOS X El Capitan 10.11.6 or later
Expansion and Connectivity
- 1 x USB-C , 1 x Smart Connector , 1 x Magnetic connector
- Technology
- Lithium polymer
- Capacity
- 29.37 Wh
- Run Time
- Up to 10 hours
- Run Time Details
- Web browsing over Wi-Fi: up to 10 hour(s) , Video playback: up to 10 hour(s) , Audio playback: up to 10 hour(s)
- Space grey
- Sensors
- Accelerometer, ambient light sensor, 3-axis gyro sensor, digital compass, barometer
- VoiceOver screen reader, AirPlay, Dictation, AssistiveTouch, iBeacon microlocation, Apple M12 motion coprocessor
- Included Accessories
- Power adapter
- Cables Included
- USB-C charge cable - 1 m
- 0.99 W/kg (body)
- Localisation
- 17.85 cm
- 0.59 cm
- 24.76 cm
- 468 g
- Limited warranty - 1 year , Technical support - phone consulting - 90 days
- 0 °C
- 35 °C
- 5 - 95% (non-condensing)
- Min Storage Temperature
- -20 °C
- Max Storage Temperature
- 45 °C
- Max Altitude Operating
- 3 km
Apple USB-C to USB Adapter | In Stock | £17.39 |
Apple USB-C Charge Cable (2m) | In Stock | £15.82 |
Apple Magic Keyboard Keyboard and Folio Case with Trackpad Backlit | In Stock | £266.75 |
Apple AirTag 4-Pack | In Stock | £99.17 |
