The Smart battery case gives you even longer battery life while offering great protection. Inside, a soft microfiber lining helps protect your phone. And on the outside, the silky, soft-touch finish of the silicone exterior feels great in your hand. A soft elastomer hinge design makes it easy to put the case on and take it off.
- Apple Smart - battery case for mobile phone
- Product Type
- Battery case for mobile phone
- Material
- Silicone
- Black
- Designed For
- iPhone XS Max
- Material
- Silicone
- Lining Material
- Microfibre
- Black
Carrying Case
- Battery case
- Recommended Use
- For mobile phone
- Wireless Charging Standards
- Qi
- Technology
- Lithium
- Designed For
- Apple iPhone XS Max
