Ideal for use where cables are prone to be added to, moved or removed, the high quality adjustable ties are re-useable and screw mountable. The soft fabric design means a high degree of cable safety - possible cable crushing is minimized.
- APLIX Hook & Loop cable tie
- Product Type
- Cable tie
- Packaged Quantity
- 25 (specifications are for single item)
- 0.9 cm
- Length
- 15.2 cm
- Black
- Packaged Quantity
- Product Type
- Cable tie
- 0.9 cm
- Length
- 15.2 cm
- Enclosure Colour
- Black
