APC Wiring Closet Ventilation Unit with Enviro MGT
Quicklinx: 787VWS00 Mfr#: ACF301EM
Combined together, the wiring closet ventilation unit and the environmental manager provide users the ability to remotely monitor and control the cooling of their networking closet.
  • Dual fans
    Provides fault tolerance in the event of a fan failure
  • Network interface
    Provides management by connecting the device directly to the network with a dedicated IP address, avoiding the need for a proxy such as a server. Management is available via Web browser, Telnet or SSH. Notification features inform you of problems as they occur
  • Programmable input/output contacts
    Allows device contacts to be connected to the air conditioner and mapped to customer outputs or system alarms
  • Remote management
    Remote monitoring of key alarm conditions such as fan failure and leak detection via SNMP, telnet, and web browser is possible with optional Remote Monitoring Unit, specifically designed for the High-Density Cooling Enclosure
  • Temperature/humidity probe
    Monitors the room temperature and relative humidity up to 12 feet away. Can be used for controlling set points
APC Room Air Distribution Wiring Closet Ventilation Unit with Environmental Management ventilation unit
Ventilation unit
Placing / Mounting
Wall mountable
Black, beige
43.4 cm x 17.8 cm x 36.8 cm
12 kg
Ventilation unit
Placing / Mounting
Wall mountable
43.4 cm
17.8 cm
36.8 cm
12 kg
Black, beige
Limited warranty - replace or repair - 2 years
45 °C
