APC Vertical Cable Organizer, NetShelter SX, 42U
Quicklinx: 89BSWS00 Mfr#: AR7502
Power Rating: [N/A]
Stock Status: Used Stock
£77.28 ex VAT
£92.73 inc VAT
Cable management accessory is designed to help eliminate cable stress and maintain a neat, organized cable layout within an enclosure or a rack.
APC rack cable management kit
Rack cable management kit
11.7 cm x 1.3 cm x 193 cm
2.3 kg
Vertical orientation
P/N: NBDC0001, SMC1000I-2UC, SMC1500I-2UC, SMC1500IC, SRT1000RMXLI, SRT1000RMXLI-NC, SRT5KRMXLW-HW, SUA5000RMI5U, SURT1000XLI, SURT2000XLI, SYA8K8RMI
11.7 cm
1.3 cm
193 cm
2.3 kg
Mounting Kit
Included
Used stock
What is used stock?
Accessories Packaging Functional Software Manuals
Ref: 89BS 034898
Condition: Damaged stock - Item is new but has packaging damage
This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  £5.84
Legend
  • This part of the stock item is present and in good conditionThis part of the stock item is present and in good condition
  • This part of the stock item is not present or functionalThis part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standardThis part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.This item has not been tested.
Power Rating: [N/A]
Brand: APC
Price Range Ex VAT: 50 - 100
