Hot-scalable power, runtime and distribution in a high-density single frame design. This high-efficiency 3-phase UPS scales as your data center grows up to 48kW/48kVA. It is suitable for small and medium data center applications.
Automatic self-test
Periodic battery self-test ensures early detection of a battery that needs to be replaced -
Intelligent battery management
Maximizes battery performance, life, and reliability through intelligent, precision charging -
Temperature-compensated battery charging
Prolongs battery life by regulating the charge voltage according to battery temperature -
Battery modules connected in parallel
Delivers higher availability through redundant batteries -
Battery replacement without tools
Enables fast battery replacement, lowering Mean Time to Repair (MTTR) -
Dual mains input
Increases availability by allowing the UPS to be connected to two separate power sources -
Manageable external batteries
Reduces preventative maintenance service needs by monitoring the health and status of the external batteries and their expected runtime -
Swappable batteries
Allows quick addition of runtime capacity or replacement of existing battery modules. Installed modules are automatically recognized by the system
- APC Symmetra PX All-In-One 16kW Scalable to 48kW - UPS - 16 kW - 16000 VA
- UPS - external
- Rack Size
- 42U
- 537 kg
- Input Wiring
- 3-phase
- Input Voltage
- AC 400 V
- Output Voltage
- AC 230/380/400/415 V ± 2%
- Power Capacity
- 16 kW / 16000 VA
- Input Connectors
- 1 x hardwire 5-wire (3PH + N + G)
- Output connectors
- Batteries Qty
- 8 (installed) / 10 (supported)
- Run Time (Up To)
- 10.4 min at full load
- Black
- 60 cm x 107 cm x 199 cm
- 1-year warranty
- UPS - external
- Height (Rack Units)
- 42U
- Black
- UPS Technology
- On-line
- Input Voltage
- AC 400 V
- Input Voltage Range
- AC 340 - 477 V
- Frequency Provided
- 50/60 Hz
- Input Voltage Margin
- ± 5%
- Input Wiring
- 3-phase
- Frequency Required
- 40 - 70 Hz
- Input Connectors
- Power Output Connectors Details
- Output Voltage
- AC 230/380/400/415 V ± 2% - 50/60 Hz
- Power Capacity
- 16 kW / 16000 VA
- Output Waveform
- Sinewave
- Circuit Protection
- Circuit breaker
- Quantity
- Run Time (Up To)
- Recharge Time
- 3 hours
- 1 x EPO (emergency power off)
- Expansion Slots
- 2 SmartSlot
- Audible alarm, emergency power off, LCD display, built-in static bypass
- IEC 62040-3, IEC 62040-1-1, EN 50091-1, FCC Part 15 A
- Limited warranty - 1 year - on-site
- 0 °C
- 40 °C
- Sound Emission
- 61 dBA
- 60 cm
- 107 cm
- 199 cm
- 537 kg
- Shipping Width
- 84.8 cm
- Shipping Depth
- 121 cm
- Shipping Height
- 214 cm
- Shipping Weight
- 578 kg
