APC Symmetra LX Extended Run Tower W/9 SYBT5, 230V
Quicklinx: 86DGWS00 Mfr#: SYAXR9B9I
Modular design
  • Increases adaptability with an open architecture configurable to any IT environment.
  • Modular construction - can be deployed as a non-standby and migrate to a standby (UPS) system.
Hot-swappable batteries
  • Ensures clean, uninterrupted power to protected equipment while batteries are being replaced
Battery modules connection in panel
  • Delivers higher availability through redundant batteries.
User-replaceable batteries
  • Increases availability by allowing a trained user to perform upgrades and replacements of the batteries reducing Mean Time to Repair (MTTR)
Stackable external battery frames
  • Saves floor space without compromising runtime requirements.
Plug-and-Play external batteries
  • Ensures clean, uninterrupted power to the loads when adding extra runtime to the UPS.
  • Battery modules connected in parallel
  • Hot-swappable batteries
  • Modular design
  • Plug-and-play external batteries
  • Stackable external battery frames
  • User-replaceable batteries
    Increases availability by allowing a trained user to perform upgrades and replacements of the batteries reducing Mean Time to Repair (MTTR).
APC Extended Run - power array cabinet
Power array cabinet - external
349 kg
Input Voltage
AC 230 V
Lead Acid
Battery Form Factor
Plug-in module
Batteries Qty
9 (supported) 9
48.3 cm x 72.6 cm x 60.2 cm
P/N: ISXCR1SY16K16P5, ISXT216MD1RI, SYA12K16I, SYA12K16ICH, SYA12K16IXR, SYA12K16IXRCH, SYA12K16RMICH, SYA16K16I, SYA16K16ICH, SYA16K16IXR, SYA16K16IXRCH, SYA16K16RMI, SYA16K16RMICH, SYA4K8I, SYA4K8RMI, SYA8K16I, SYA8K16ICH, SYA8K16IXR, SYA8K16RMI, SYA8K16RMICH, SYA8K8I, SYA8K8RMI, SYAF16KRMICH
Battery Enclosure Type
Plug-in module
Supported Battery Technology
Lead Acid
Input Voltage
AC 230 V
Quantity
9 (supported) 9
Lead Acid
Voltage Provided
120 V
CSA, VCCI, BSMI, EN 60950, UL 1778, VDE, IEC 60950, EN 50091-2, EN 50091-1
0 - 95%
48.3 cm
72.6 cm
60.2 cm
349 kg
P/N: ISXCR1SY16K16P5, ISXT216MD1RI, SYA12K16I, SYA12K16ICH, SYA12K16IXR, SYA12K16IXRCH, SYA12K16P, SYA12K16PXR, SYA12K16RMI, SYA12K16RMICH, SYA12K16RMP, SYA16K16I, SYA16K16ICH, SYA16K16IXR, SYA16K16IXRCH, SYA16K16P, SYA16K16PXR, SYA16K16RMI, SYA16K16RMICH, SYA16K16RMP, SYA4K8I, SYA4K8P, SYA4K8RMI, SYA4K8RMP, SYA8K16I, SYA8K16ICH, SYA8K16IXR, SYA8K16P, SYA8K16PXR, SYA8K16RMI, SYA8K16RMICH, SYA8K16RMP, SYA8K8I, SYA8K8P, SYA8K8RMI, SYA8K8RMP, SYAF16KRMICH
