Engineered to deliver the highest level of business continuity possible, the Symmetra LX uses a modular, redundant architecture that can scale power and run-time as demand increases or when higher levels of availability are required. Advancements in this next generation design greatly decrease footprint or U-space needed in an equipment rack, increase speed and ease of deployment and reduce repair time. With built-in network manageability, the on-line Symmetra LX is the choice to protect high-performance IT and telecom equipment in computer rooms and small data centers.
- APC Symmetra LX 16kVA Scalable to 16kVA N+1 - power array - 16000 VA
- Power array - external
- 504 kg
- Input Voltage
- AC 220/230/240/380/400/415 V
- Output Voltage
- AC 230/240 V ± 5%
- Power Capacity
- 16000 VA
- Input Connectors
- Hardwire
- Output connectors
- 1 x hardwire
- Battery
- Lead Acid
- Batteries Qty
- 9
- Run Time (Up To)
- 24.7 min at full load
- Black, silver
- 48 cm x 73 cm x 152 cm
- 2-year warranty
- Black, silver
- Supported Battery Technology
- Lead Acid
- Input Voltage
- Input Voltage Range
- AC 155/276 - 290/480 V
- Frequency Provided
- 47 - 63 Hz
- Frequency Required
- 45 - 65 Hz
- Input Connectors
- Hardwire
- Power Output Connectors Details
- 1 x hardwire
- Output Voltage
- AC 230/240 V ± 5% - 47 - 63 Hz
- Power Capacity
- 16000 VA
- Output Waveform
- Sinewave
- Quantity
- 9
- Technology
- Lead Acid
- Run Time (Up To)
- 1 x management (RS-232) - 9 pin D-Sub (DB-9)
- Expansion Slots
- 1 (free) x SmartSlot
- C-Tick, GOST, EN 60950, VDE, IEC 60950, EN55024, EN55022 Class A, EN 50091-2
- Limited warranty - 2 years
- 0 °C
- 40 °C
- 0 - 95%
- 48 cm
- 73 cm
- 152 cm
- 504 kg
