APC Symmetra LX 16kVA Scalable to 16kVA N+1 Ext. Run Tower,
Quicklinx: 86CSWS00 Mfr#: SYA16K16IXR
Engineered to deliver the highest level of business continuity possible, the Symmetra LX uses a modular, redundant architecture that can scale power and run-time as demand increases or when higher levels of availability are required. Advancements in this next generation design greatly decrease footprint or U-space needed in an equipment rack, increase speed and ease of deployment and reduce repair time. With built-in network manageability, the on-line Symmetra LX is the choice to protect high-performance IT and telecom equipment in computer rooms and small data centers.
  • Removable input/output wiring tray
    Allows quick and easy installation and maintenance of the UPS
APC Symmetra LX 16kVA Scalable to 16kVA N+1 - power array - 16000 VA
Power array - external
504 kg
Input Voltage
AC 220/230/240/380/400/415 V
Output Voltage
AC 230/240 V ± 5%
Power Capacity
16000 VA
Input Connectors
Hardwire
Output connectors
1 x hardwire
Lead Acid
Batteries Qty
9
Run Time (Up To)
24.7 min at full load
Black, silver
48 cm x 73 cm x 152 cm
Black, silver
Supported Battery Technology
Lead Acid
Input Voltage
Input Voltage Range
AC 155/276 - 290/480 V
Frequency Provided
47 - 63 Hz
Frequency Required
45 - 65 Hz
Input Connectors
Hardwire
1 x hardwire
Output Voltage
AC 230/240 V ± 5% - 47 - 63 Hz
Power Capacity
16000 VA
Output Waveform
Sinewave
Quantity
9
Lead Acid
Run Time (Up To)
1 x management (RS-232) - 9 pin D-Sub (DB-9)
Expansion Slots
1 (free) x SmartSlot
C-Tick, GOST, EN 60950, VDE, IEC 60950, EN55024, EN55022 Class A, EN 50091-2
0 - 95%
48 cm
73 cm
152 cm
504 kg
