APC Switched Rack PDU AC 208-230 V Ethernet
Quicklinx: CWN4WS00 Mfr#: AP7921B
16 in stock
£576.86 ex VAT
£692.23 inc VAT
The aggregate current draw per power distribution unit is displayed on the unit via a digital display. The local digital display helps installers avoid overloaded circuits by providing a visible warning when the current draw is close to the maximum amperage draw of the strip.
Define alarm thresholds in order to avoid overloaded circuits. Network and visual alarms inform the user of possible problems.
Full-featured network management interfaces that provide standards-based management via web, SNMP, and telnet. Allows users to access, configure, and manage units from remote locations to save valuable time. Associated with this feature is the ability to quickly and easily upgrade the firmware via network download to installed units for future product enhancements.
APC Switched Rack PDU - power distribution unit
Power distribution unit - rack-mountable
Cord Length
2.4 m
Rack Size
1U
2.26 kg
Input Voltage
AC 208-230 V
Input Connectors
1 x power IEC 60320 C20
Output connectors
8 x power IEC 60320 C13
Ethernet, RS-232
Remote Management Protocol
SNMP, Telnet, HTTP
44.45 cm x 10.8 cm x 4.45 cm
P/N: DLT3000RMI2U, SMC1000I-2UC, SMC1500I-2UC, SMC1500IC, SMT2200RMI2UC, SMX2200HV, SMX2200HVNC, SMX3000HV, SMX3000HVNC, SRT1000RMXLI, SRT1000RMXLI-NC, SRT1500XLI, SRT2200RMXLI-NC, SRT2200XLI-KR, SRT3000RMXLI-NC, SRT5KRMXLIM, SRT5KRMXLW-HW, SRT6KRMXLIM, SUA2200R2X180, SUA5000RMI5U, SURTD2200XLIM
Height (Rack Units)
1U
Cord Length
2.4 m
Input Voltage
AC 208-230 V
Input Voltage Range
AC 200 - 240 V
Frequency Required
50/60 Hz
Input Connectors
Max Electric Current
16 A
Remote Management Interface
Ethernet, RS-232
SNMP, Telnet, HTTP
1 x management (Ethernet) , 1 x management (RS-232)
Power cable 2.4 m
Rack Mounting Kit
Included
UL, VCCI, cUL, EN55022, ICES-003, VDE, EN55024, FCC Part 15 A, AS/NZS
-5 °C
45 °C
5 - 95% (non-condensing)
44.45 cm
10.8 cm
4.45 cm
2.26 kg
Shipping Weight
3.4 kg
P/N: DLT3000RMI2U, SMC1000I-2UC, SMC1500I-2UC, SMC1500IC, SMT2200RMI2UC, SMX2200HV, SMX2200HVNC, SMX3000HV, SMX3000HVNC, SRT1000RMXLI, SRT1000RMXLI-NC, SRT1500XLI, SRT2200RMXLI-NC, SRT2200XLI-KR, SRT3000RMXLI-NC, SRT5KRMXLIM, SRT5KRMXLW-HW, SRT6KRMXLIM, SUA2200R2X180, SUA5000RMI5U, SURT1000XLI, SURT2000XLI, SURTD2200XLIM, SYA8K8RMI
Brand: APC
Price Range Ex VAT: 500 - 750
