APC Smart-UPS X-Series 48V Ext. Batt Pack Rack/Tower
Quicklinx: 74C6WS00 Mfr#: SMX48RMBP2U
Type: Battery
Power Rating: [N/A]
Stock Status: In Stock, Used Stock
27 in stock
£522.78 ex VAT
£627.33 inc VAT
Hot-swappable batteries
Ensures clean, uninterrupted power to protected equipment while batteries are being replaced
Intelligent battery management
Maximizes battery performance, life, and reliability through intelligent, precision charging.
Rack/Tower convertible
Protects the initial investment in the UPS when migrating from tower to rack-mount environment.
  • Intelligent battery management
  • Hot-swappable batteries
  • Rack/Tower convertible
APC Smart-UPS X 48V External Battery Pack Rack/Tower - battery enclosure - Lead Acid - 864 mAh
Battery enclosure - rack-mountable
Rack Size
2U
28.6 kg
Output Voltage
48 V
Lead Acid - 864 mAh
Battery Form Factor
Plug-in module
Batteries Qty
2
Wall mounting bracket
43.2 cm x 49 cm x 8.9 cm
P/N: SMX1000I-1YR, SMX1000I-3XW, SMX1000I-3YRS, SMX1000I-5XW, SMX1000I-DIG, SMX1000RMI2U, SMX1500RMI2U-3XW, SMX1500RMI2U-3YRS, SMX1500RMI2U-5XW, SMX1500RMI2UNC-1YR, SMX1500RMI2UNC-3XW, SMX1500RMI2UNC-3YRS, SMX1500RMI2UNC-5XW, SMX750I-1YR, SMX750I-3XW, SMX750I-3YRS, SMX750I-5XW, SMX750I-DIG
Battery Enclosure Type
Plug-in module
Height (Rack Units)
2U
Output Voltage
48 V
Quantity
2
Lead Acid
864 mAh
Hot-swappable
RoHS Exemption 7b
43.2 cm
49 cm
8.9 cm
28.6 kg
Shipping Width
58.9 cm
Shipping Depth
62 cm
Shipping Height
24.6 cm
P/N: SMX1000, SMX1000I, SMX1000I-1YR, SMX1000I-3XW, SMX1000I-3YRS, SMX1000I-5XW, SMX1000I-DIG, SMX1000RMI2U, SMX1500RM2U, SMX1500RM2UNC, SMX1500RMI2U, SMX1500RMI2U-1YR, SMX1500RMI2U-3XW, SMX1500RMI2U-3YRS, SMX1500RMI2U-5XW, SMX1500RMI2UC, SMX1500RMI2UNC, SMX1500RMI2UNC-1YR, SMX1500RMI2UNC-3XW, SMX1500RMI2UNC-3YRS, SMX1500RMI2UNC-5XW, SMX750, SMX750I, SMX750I-1YR, SMX750I-3XW, SMX750I-3YRS, SMX750I-5XW, SMX750I-DIG
Used stock
What is used stock?
Accessories Packaging Functional Software Manuals
Ref: 74C6 039660
Condition: Customer return - item has been opened but is in excellent condition
This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  This part of the stock item is not applicable e.g. it might not include accessories or software as standard  This part of the stock item is present and in good condition  £332.40
Legend
  • This part of the stock item is present and in good conditionThis part of the stock item is present and in good condition
  • This part of the stock item is not present or functionalThis part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standardThis part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.This item has not been tested.
Type: Battery
Power Rating: [N/A]
Brand: APC
Stock Status: Used Stock
Price Range Ex VAT: 500 - 750
