Product
APC Smart-UPS VT 30kVA 400V w/4 Batt. Mod.  Start-Up 5X8  In
Quicklinx: 86DFWS00 Mfr#: SUVTP30KH4B4S
Type: Battery
Power Rating: 24kW
£9,480.19 ex VAT
£11,376.22 inc VAT
Smart-UPS VT offers centralized three-phase power protection with the reliability of the award winning Smart-UPS family. Ideal for small data centers, large retail stores, regional offices, and dense power requirements, the Smart-UPS VT includes dual-mains input, automatic and maintenance bypasses, and scalable runtime with hot-swappable batteries for increased availability. Low cost of ownership is achieved through best-in-class efficiency and a reduction in rating of electrical infrastructure - wires, transformers, and generators due the Smart-UPS VT's Soft Start feature. Serviceability is greatly enhanced by user-replaceable batteries. All these features make the Smart-UPS VT is the easiest UPS in its class to deploy, manage and maintain.
  • Parallel-capacity capable
    Increases total power capacity by using multiple uninterruptible power supplies simultaneously
  • Parallel-redundant capable
    Power the connected equipment with multiple uninterruptible power supplies to increase system redundancy
APC Smart-UPS VT 30kVA with 4 Battery Modules - UPS - 24 kW - 30000 VA
UPS - external
629 kg
Input Wiring
3-phase
Input Voltage
AC 380/400/415 V
Output Voltage
AC 230/380/400/415 V ± 5%
Power Capacity
24 kW / 30000 VA
Input Connectors
1 x hardwire 5-wire (3PH + N + G)
Output connectors
1 x hardwire 4-wire (3PH + G) , 1 x hardwire 5-wire (3PH + N + G) , 1 x terminal block
Lead Acid
Battery Form Factor
Internal
Batteries Qty
4 (installed) / 4 (supported)
Run Time (Up To)
9.5 min at full load
Ethernet 10/100, RS-232
Remote Management Protocol
SNMP, Telnet, HTTP, HTTPS, WAP
Bolt down brackets
55.9 cm x 81.3 cm x 150 cm
1 year warranty
UPS - external
Battery Enclosure Type
Internal
UPS Technology
On-line
Input Voltage
AC 380/400/415 V
Input Voltage Range
AC 304 - 477 V
Frequency Provided
47 - 53 Hz
Input Wiring
3-phase
Frequency Required
40 - 70 Hz
Input Connectors
Output Voltage
AC 230/380/400/415 V ± 5% - 47 - 53 Hz
Power Capacity
24 kW / 30000 VA
Output Waveform
Sinewave
Surge Suppression
Circuit Protection
Circuit breaker
Quantity
Lead Acid
Run Time (Up To)
Recharge Time
5 hours
Remote Management Interface
1 x management (Ethernet) - RJ-45 , 1 x EPO (emergency power off) , 1 x management (RS-232) - 9 pin D-Sub (DB-9)
Expansion Slots
1 (total) / 0 (free) x SmartSlot
Bolt down brackets
Audible alarm, emergency power off, LCD display, Parallel Capability, built-in maintenance bypass, built-in static bypass
C-Tick, ISO 9001, EN 61000-3-2, IEC 61000-3-2, IEC 61000-3-3, ISO 14001, EN 50091-2, IEC 62040-3
Limited warranty - 1 year , Installation
0 - 95%
Sound Emission
64 dBA
55.9 cm
81.3 cm
150 cm
629 kg
Shipping Width
65 cm
Shipping Depth
106 cm
Shipping Height
164 cm
Shipping Weight
660 kg
Type: Battery
Power Rating: 24kW
Brand: APC
Price Range Ex VAT: 1500+
