Product
APC Smart-UPS VT 10kVA 400V
Quicklinx: 8TK0WS00 Mfr#: SUVTP10KH2B4S
Type: UPS
Power Rating: 8kW, 8kW
£6,713.43 ex VAT
£8,056.11 inc VAT
Smart-UPS VT offers IT professionals the performance and legendary reliability of the award winning Smart-UPS family. Expanding up through to small data centers, remote offices, Point of Sale applications and laboratory equipment Smart-UP VT is ideal for entry level and performance power protection needs. Smart-UPS VT features double-conversion on-line design and offers internal and external batteries in a user friendly, scalable design. The UPS includes dual mains input for increased availability and a built-in maintenance bypass breaker.
  • Parallel-capacity capable
    Increases total power capacity by using multiple uninterruptible power supplies simultaneously
  • Parallel-redundant capable
    Power the connected equipment with multiple uninterruptible power supplies to increase system redundancy
APC Smart-UPS VT 10kVA with 2 Battery Modules Expandable to 4 - UPS - 8 kW - 10000 VA
UPS - external
415 kg
Input Wiring
3-phase
Input Voltage
AC 380/400/415 V
Output Voltage
AC 380/400/415 V ± 5%
Power Capacity
8 kW / 10000 VA
Input Connectors
1 x hardwire 5-wire (3PH + N + G)
Output connectors
1 x Terminal Block (Screw) , 1 x hardwire 5-wire (3PH + N + G) , 1 x hardwire 4-wire (3PH + G)
Lead Acid expandable
Battery Form Factor
Internal
Batteries Qty
2 (installed) / 4 (supported)
Run Time (Up To)
18.5 min at full load
Ethernet 10/100, RS-232
Remote Management Protocol
SNMP, Telnet, HTTP, HTTPS
Bolt down brackets
55.9 cm x 81.3 cm x 150 cm
1 year warranty
UPS - external
Battery Enclosure Type
Internal
UPS Technology
On-line
Input Voltage
AC 380/400/415 V
Input Voltage Range
AC 304 - 477 V
Frequency Provided
47 - 53 Hz
Input Wiring
3-phase
Frequency Required
47 - 70 Hz
Input Connectors
Output Voltage
AC 380/400/415 V ± 5% - 47 - 53 Hz
Power Capacity
8 kW / 10000 VA
Output Waveform
Sinewave
Surge Suppression
Circuit Protection
Circuit breaker
Expandable
Quantity
Lead Acid
Voltage Provided
192 V
Run Time (Up To)
Recharge Time
5 hours
Remote Management Interface
1 x management (Ethernet) - RJ-45 , 1 x EPO (emergency power off) , 1 x management (RS-232) - 9 pin D-Sub (DB-9)
Expansion Slots
1 (total) / 0 (free) x SmartSlot
Bolt down brackets
Audible alarm, emergency power off, LCD display, Parallel Capability, built-in maintenance bypass, built-in static bypass
C-Tick, ISO 9001, IEC 61000-3-2, IEC 61000-3-3, ISO 14001, IEC 60529 IP20, EN 50091-2, IEC 62040-3
Software Included
Drivers & Utilities
Limited warranty - 1 year , Installation , Technical support - training
0 - 95%
Sound Emission
54 dBA
55.9 cm
81.3 cm
150 cm
415 kg
Shipping Width
65 cm
Shipping Depth
106 cm
Shipping Height
164 cm
Shipping Weight
446 kg
Type: UPS
Power Rating: 8kW
Power Rating: 8kW
Brand: APC
Price Range Ex VAT: 1500+
