APC Smart-UPS SRT UPS  5000 Watt  Lead Acid
Quicklinx: 9N8XWS00 Mfr#: SRT5KRMXLI
Type: Battery
Power Rating: 4500Watt
21 in stock
£2,919.75 ex VAT
£3,503.70 inc VAT
LCD graphics display has text and mimic diagrams that display modes of operation, system parameters and alarms. Connect the device to a network using a 10 or 100 BASE-T connection. Green mode bypasses unused electrical components in good power conditions to achieve high operating efficiency without sacrificing protection. Battery failure notification provides early-warning fault analysis on batteries enabling timely preventive maintenance. Automatic internal bypass supplies utility power to the connected loads in the event of a UPS power overload or fault. Scalable runtime allows additional run time to be quickly added as needed. Intelligent battery management maximizes battery performance, life, and reliability through intelligent, precision charging.
  • Green mode
    Patent-pending operating mode that bypasses unused electrical components in good power conditions to achieve very high operating efficiency without sacrificing any protection
  • Battery failure notification
    Provides early-warning fault analysis on batteries enabling timely preventive maintenance
  • LCD graphics display
    Text and mimic diagrams that display modes of operation, system parameters and alarms
  • ECO Mode
    Operating mode that by-passes unused electrical components in good power conditions to achieve high operating efficiency without sacrificing protection
  • 10/100 BaseT Connection
    Connect the device to a network using a 10 or 100 BaseT connection
APC Smart-UPS SRT 5000VA RM - UPS - 4500 Watt - 5000 VA
UPS - rack-mountable
Rack Size
3U
54.55 kg
Input Voltage
AC 230 V
Output Voltage
AC 230 V ± 3%
Power Capacity
4500 Watt / 5000 VA
Input Connectors
Hardwire 3-wire (1PH + N + G)
Output connectors
6 x power IEC 60320 C13 , 4 x power IEC 60320 C19 , 2 x IEC connector
Lead Acid
Run Time (Up To)
4 min at full load
USB
43.2 cm x 71.9 cm x 13 cm
3-year warranty
Height (Rack Units)
3U
UPS Technology
On-line
Input Voltage
AC 230 V
Frequency Provided
50/60 Hz
Frequency Required
45 - 65 Hz
Input Connectors
Output Voltage
AC 230 V ± 3% - 50/60 Hz
Power Capacity
4500 Watt / 5000 VA
Output Waveform
Sinewave
Surge Suppression
Surge Energy Rating
480 Joules
Efficiency
98%
Lead Acid
Run Time (Up To)
4 min at full load , 11.8 min at half load
Recharge Time
3 hours
Maintenance free, sealed, leak-proof
Remote Management Interface
USB
1 x serial - RJ-45 , 1 x management (USB) - 4 pin USB Type B , 1 x EPO (emergency power off)
Expansion Slots
1 (total) / 1 (free) x SmartSlot
Audible alarm, LCD display
C-Tick, VDE, IEC 60950, EN 50091-2, RoHS, EN 50091-1, REACH, EN 62040-2, IP20, EAC
Limited warranty - 3 years , Limited warranty - batteries - 2 years
0 - 95% (non-condensing)
Sound Emission
55 dBA
43.2 cm
71.9 cm
13 cm
54.55 kg
Shipping Width
61 cm
Shipping Depth
96 cm
Shipping Height
33 cm
Shipping Weight
63.6 kg
9N8X C2G .45m USB to DB9 Serial Adapter Cable In Stock £12.50
9N8X C2G 2M DB9 M/F ALL LINES EXT CBL BLK In Stock £5.14
9N8X C2G 10m DB9 M/F Extension Cable Black In Stock £12.16
9N8X C2G 5m DB9 M/F Extension Cable - Black In Stock £8.06
Type: Battery
Brand: APC
Price Range Ex VAT: 1500+
