APC Smart-UPS SRT 8000VA RM 230V
Quicklinx: B3PNWS00 Mfr#: SRT8KRMXLI
Type: UPS
Power Rating: 8000watt
10 In Stock
£6,299.84 ex VAT
£7,559.80 inc VAT
LCD graphics display has text and mimic diagrams that display modes of operation, system parameters and alarms. Connect the device to a network using a 10 or 100 BASE-T connection. Green mode bypasses unused electrical components in good power conditions to achieve very high operating efficiency without sacrificing any protection. Battery failure notification provides early-warning fault analysis on batteries enabling timely preventive maintenance. Automatic internal bypass supplies utility power to the connected loads in the event of a UPS power overload or fault. Scalable runtime allows additional run time to be quickly added as needed. Intelligent battery management maximizes battery performance, life, and reliability through intelligent, precision charging.
  • LCD graphics display
    Text and mimic diagrams that display modes of operation, system parameters and alarms.
  • 10/100 BaseT connection
    Connect the device to a network using a 10 or 100 BaseT connection
  • Green mode
    Patent-pending operating mode that bypasses unused electrical components in good power conditions to achieve very high operating efficiency without sacrificing any protection.
  • Battery failure notification
    Provides early-warning fault analysis on batteries enabling timely preventive maintenance
APC Smart-UPS SRT 8000VA RM - UPS - 8000 watt - 8000 VA
UPS - rack-mountable
Rack Size
6U
111.82 kg
Input Voltage
AC 230 V
Output Voltage
AC 230 V ± 3%
Power Capacity
8000 watt / 8000 VA
Input Connectors
Hardwire 5-wire (3PH + N + G), hardwire 3-wire (1PH + N + G)
Output connectors
6 x power IEC 60320 C13 , 4 x power IEC 60320 C19 , 1 x hardwire 3-wire (HN + G) , 3 x IEC connector
Lead Acid
Run Time (Up To)
5.3 min at full load
Ethernet 10/100, USB
43.2 cm x 71.5 cm x 26.3 cm
3-year warranty
P/N: ACDC2513, AR2401, AR2487G, AR2507, AR2580, AR2587, AR3100G, AR3100TAA, AR3100W, AR3105SP, AR3105W, AR3107G, AR3107SP, AR3150SP, AR3150W, AR3155SP, AR3155W, AR3157SP, AR3300G, AR3300SP, AR3300W, AR3305SP, AR3305W, AR3307SP, AR3307W, AR3350SP, AR3350W, AR3355SP, AR3355W, AR3357SP, NBWL0356A
Height (Rack Units)
6U
UPS Technology
On-line
Input Voltage
AC 230 V
Frequency Provided
50/60 Hz
Frequency Required
45 - 65 Hz
Input Connectors
Output Voltage
AC 230 V ± 3% - 50/60 Hz
Power Capacity
8000 watt / 8000 VA
Output Waveform
Sinewave
Surge Suppression
Surge Energy Rating
480 joules
Efficiency
98%
Lead Acid
Run Time (Up To)
5.3 min at full load , 14.8 min at half load
Recharge Time
3 hours
Maintenance free, sealed, leak-proof
Remote Management Interface
1 x management (Ethernet) - RJ-45 , 1 x management (USB) - 4 pin USB Type B , 1 x EPO (emergency power off) , 1 x serial - RJ-45
Expansion Slots
1 (total) / 1 (free) x SmartSlot
Audible alarm, LCD display
C-Tick, VDE, IEC 60950, EN 50091-2, RoHS, EN 50091-1, REACH, EN 62040-2, IP20, EAC
Software Included
APC PowerChute Business Edition
Limited warranty - 3 years , Limited warranty - batteries - 2 years
0 - 95% (non-condensing)
Sound Emission
55 dBA
43.2 cm
71.5 cm
26.3 cm
111.82 kg
Shipping Width
60 cm
Shipping Depth
1 m
Shipping Height
46.1 cm
Shipping Weight
130 kg
P/N: ACCS1000, ACCS1001, ACCS1002, ACCS1003, ACCS1004, ACCS1005, ACCS1006, ACCS1007, ACDC1015, ACDC1016, ACDC1017, ACDC1019, ACDC1020, ACDC2513, ACF001, ACF002, AP5017, AP5602, AP5606, AP5607, AP5616, AP92200, AP9290, AR2400, AR2400FP1, AR2401, AR2407, AR2480, AR2487, AR2487G, AR2500, AR2507, AR2580, AR2587, AR3000, AR3100, AR3100G, AR3100SP, AR3100SP1, AR3100SP2, AR3100TAA, AR3100W, AR3100X609, AR3100X610, AR3100X617, AR3101, AR3104, AR3104SP1, AR3105, AR3105SP, AR3105W, AR3107, AR3107G, AR3107SP, AR3107X609, AR3107X610, AR3107X617, AR3130, AR3150, AR3150SP, AR3150SP1, AR3150SP2, AR3150W, AR3150X609, AR3150X610, AR3150X617, AR3155, AR3155SP, AR3155W, AR3157, AR3157SP, AR3157X609, AR3157X610, AR3157X617, AR3200, AR3300, AR3300G, AR3300SP, AR3300W, AR3300X609, AR3300X610, AR3300X617, AR3305, AR3305SP, AR3305W, AR3307, AR3307SP, AR3307W, AR3307X609, AR3307X610, AR3307X617, AR3350, AR3350SP, AR3350W, AR3350X609, AR3350X610, AR3350X617, AR3355, AR3355SP, AR3355W, AR3357, AR3357SP, AR3357X609, AR3357X610, AR3357X617, AR7007, AR7050, AR7057, AR8135BLK, NBWL0356A
B3PN APC Power Cord IEC 320 C13 to IEC 320 C14 In Stock £30.76
B3PN APC Power Cord IEC 320 C19 TO IEC 320 C14 In Stock £50.67
B3PN APC Basic Rack-Mount PDU - power distribution strip In Stock £206.60
B3PN APC 1U Vertical Cable Organiser In Stock £125.43
B3PN APC 1U Horizontal Cable Organiser In Stock £56.26
B3PN APC Pwr Cord, 10A, 230V, C14 to UK rec In Stock £54.79
B3PN APC Netshelter heavy duty shelf In Stock £144.42
B3PN APC Power cable - 2.4 m In Stock £86.10
B3PN APC Rack PDU Basic Zero U 32A 230V In Stock £330.64
B3PN C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £3.67
B3PN C2G 10m Cat6 550 MHz Snagless Patch Cable - Black In Stock £9.82
B3PN APC Temperature and Humidity Sensor In Stock £132.19
B3PN APC Rack PDU Basic 1U 16A 208&230V (10)C13 & (2)C19 In Stock £297.98
B3PN APC Cable Managers (Qty 10) In Stock £36.89
B3PN APC Rack PDU 2G METERED ZEROU In Stock £710.98
B3PN APC Rack PDU 2G, Metered, ZeroU, 11kW, 230V, (36) C13 & (6) C19 In Stock £1,015.17
B3PN APC Rack PDU 2G Switched ZeroU 20A/208V 16A/230V (7) C13 & In Stock £973.78
B3PN APC Power Cord Locking C19 to C20 3.0m In Stock £70.68
B3PN APC Fixed Shelf - 50lbs/23kg, Black In Stock £82.14
B3PN APC Power Cord Kit (6 ea) Locking C19 to C20 1.2m In Stock £153.80
B3PN APC Power Cord, C19 to CEE/7 Schuko, 2.5m In Stock £55.79
B3PN APC Switched Rack PDU 2G Zero U Power Distribution Unit In Stock £1,498.11
B3PN APC NetShelter Zero U Accessory Mounting Bracket In Stock £99.78
B3PN APC Power Cord Kit (6 ea) Locking C13 to C14 0.6m In Stock £60.26
B3PN APC 1U Blanking Panel Kit In Stock £35.27
B3PN APC M6 Hardware Kit Rack Screws, Nuts and Washers In Stock £56.94
B3PN APC 1U 19" Black Modular Toolless Blanking Panel - Qty 10 In Stock £48.73
B3PN APC Power Cable (pack of 6) 1.22m In Stock £90.09
B3PN APC Rack PDU 2G Metered ZeroU 22.0kW In Stock £1,743.67
B3PN APC Horizontal Cable Manager, 1U x 4" Deep, Single-Sided In Stock £70.10
B3PN APC Power Cord Kit (6 ea) - Locking - C13 to C14 - 1.8m In Stock £133.99
B3PN APC Replacement Battery Cartridge #140 - UPS battery - Lead Acid - 960 Wh In Stock £595.61
B3PN APC Rack PDU 2G Metered ZeroU 20A/208V 16A/230V In Stock £647.80
B3PN APC Smart-UPS SRT 19 Rail Kit for Smart-UPS SRT 5/6/8/10kVA In Stock £231.46
B3PN APC Smart-UPS SRT 192V 8 and 10kVA RM Battery Pack In Stock £1,651.56
B3PN APC Switched Rack PDU AC 208-230 V Ethernet In Stock £744.71
B3PN APC Switched Rack PDU AP7922B Power Distribution Unit In Stock £1,113.73
B3PN APC Switched Rack PDU AP7920B Power Distribution Strip AC 200/20 In Stock £682.35
B3PN APC Rack PDU 2G, Metered by Outlet with Switching, ZeroU In Stock £1,285.92
B3PN APC Basic PDU 1/2 Height 100-240V/20A 14xC13 In Stock £166.36
B3PN APC Rack PDU 2G, Metered by Outlet with Switching, ZeroU, 16A, 2 In Stock £1,325.53
B3PN APC Rack PDU Basic 0U/1U 100-240V/ In Stock £84.59
B3PN APC Metered Rack 12A 1U C13x8 Power Distribution Unit In Stock £468.18
Type: UPS
Brand: APC
Price Range Ex VAT: £1500+
