APC Smart-UPS SRT 2200VA 230V
Quicklinx: CGXVWS00 Mfr#: SRT2200XLI
Power Rating: 1.98kW
£1,151.10 ex VAT
£1,381.32 inc VAT
Provides pure sine wave output which is recommended by server manufacturers using active power factor corrected (PFC) power supplies. Safety agency tested and approved means that you can deploy Smart-UPS with confidence that they meet or exceed the industry's most rigorous standards.
Network manageable via serial, USB or optional Ethernet. Includes Powerchute Network Shutdown Software for convenient monitoring and control, safe operating system shutdown, and innovative energy management capabilities.
Network grade power conditioning protects from damaging surges and disruptive noise. The double conversion architecture provides tight voltage regulation, frequency regulation, and zero transfer time to battery during power events.
  • Battery failure notification
    Provides early-warning fault analysis on batteries enabling timely preventive maintenance
  • LCD graphics display
    Text and mimic diagrams that display modes of operation, system parameters and alarms
  • ECO Mode
    Operating mode that by-passes unused electrical components in good power conditions to achieve high operating efficiency without sacrificing protection
  • Rack/Tower convertible
    Protects the initial investment in the UPS when migrating from tower to rack-mount environment
APC Smart-UPS SRT 2200VA - UPS - 1.98 kW - 2200 VA
UPS - external
25 kg
Input Voltage
AC 230 V
Output Voltage
AC 230 V ± 3%
Power Capacity
1.98 kW / 2200 VA
Input Connectors
Power IEC 60320 C20, power BS 1363A, Europlug (power CEE 7/16)
Output connectors
8 x power IEC 60320 C13 , 2 x power IEC 60320 C19
Lead Acid
Run Time (Up To)
3.9 min at full load
RS-232, USB
8.5 cm x 58.4 cm x 43.2 cm
Environmental Standards
ENERGY STAR
3-year warranty
UPS - external
UPS Technology
On-line
Input Voltage
AC 230 V
Input Voltage Range
AC 220 - 240 V
Input Voltage Range (Adjustable)
AC 100 - 275 V
Frequency Provided
50/60 Hz
Frequency Required
40 - 70 Hz
Input Connectors
Output Voltage
AC 230 V ± 3% - 50/60 Hz
Power Capacity
1.98 kW / 2200 VA
Output Waveform
Sinewave
Surge Suppression
Surge Energy Rating
340 Joules
Lead Acid
Recharge Time
3 hours
Maintenance free, sealed, leak-proof
Remote Management Interface
RS-232, USB
1 x serial - RJ-45 , 1 x EPO (emergency power off) , 1 x management (USB)
Expansion Slots
1 (total) / 1 (free) x SmartSlot
Power cable 2.44 m
Audible alarm, emergency power off, LCD display, internal bypass
VDE, IEC 62040-2, IP20, EAC, RCM, IEC 62040-1
ENERGY STAR
Limited warranty - 3 years , Limited warranty - batteries - 2 years
0 - 95% (non-condensing)
Sound Emission
55 dBA
8.5 cm
58.4 cm
43.2 cm
25 kg
Shipping Width
59.9 cm
Shipping Depth
81 cm
Shipping Height
24.6 cm
Shipping Weight
30.84 kg
Brand: APC
Price Range Ex VAT: 1000 - 1500
