APC Smart-UPS SRT 10000VA 230V
Quicklinx: BG5RWS00 Mfr#: SRT10KXLI
Text and mimic diagrams display modes of operation, system parameters and alarms.
Operating mode bypasses unused electrical components in good power conditions to achieve very high operating efficiency without sacrificing any protection.
  • Green mode
    Patent-pending operating mode that bypasses unused electrical components in good power conditions to achieve very high operating efficiency without sacrificing any protection
  • Battery failure notification
    Provides early-warning fault analysis on batteries enabling timely preventive maintenance
  • LCD graphics display
    Text and mimic diagrams that display modes of operation, system parameters and alarms
  • 10/100 BaseT Connection
    Connect the device to a network using a 10 or 100 BaseT connection
APC Smart-UPS SRT 10000VA - UPS - 10 kW - 10000 VA
UPS - rack-mountable / external
Rack Size
6U
111.82 kg
Input Voltage
AC 230 V
Output Voltage
AC 230 V ± 3%
Power Capacity
10 kW / 10000 VA
Input Connectors
Hardwire 5-wire (3PH + N + G), hardwire 3-wire (1PH + N + G)
Output connectors
6 x power IEC 60320 C13 , 4 x power IEC 60320 C19
Lead Acid
Run Time (Up To)
3.8 min at full load
Ethernet 10/100, USB
26.3 cm x 71.5 cm x 43.2 cm
3-year warranty
P/N: DLRT192RMBP, DLRT192RMBP2, SRT1500RMXLI-NC, SRT1500XLI
Height (Rack Units)
6U
UPS Technology
On-line
Input Voltage
AC 230 V
Frequency Provided
50/60 Hz
Frequency Required
45 - 65 Hz
Input Connectors
Output Voltage
AC 230 V ± 3% - 50/60 Hz
Power Capacity
10 kW / 10000 VA
Output Waveform
Sinewave
Surge Suppression
Surge Energy Rating
480 Joules
Efficiency
98%
Lead Acid
Run Time (Up To)
3.8 min at full load , 11.5 min at half load
Recharge Time
3 hours
Maintenance free, sealed, leak-proof
Remote Management Interface
1 x management (Ethernet) - RJ-45 , 1 x management (USB) - 4 pin USB Type B , 1 x EPO (emergency power off) , 1 x serial - RJ-45
Expansion Slots
1 (total) / 1 (free) x SmartSlot
Audible alarm, LCD display
C-Tick, VDE, IEC 60950, EN 50091-2, RoHS, EN 50091-1, REACH, EN 62040-2, IP20, EAC
Limited warranty - 3 years , Limited warranty - batteries - 2 years
0 - 95% (non-condensing)
Sound Emission
55 dBA
26.3 cm
71.5 cm
43.2 cm
111.82 kg
Shipping Width
60 cm
Shipping Depth
1 m
Shipping Height
46.1 cm
BG5R C2G 2M DB9 M/F ALL LINES EXT CBL BLK In Stock £4.80
BG5R C2G 3m DB9 M/F Extension Cable - Black In Stock £6.10
BG5R C2G 5m DB9 M/F Extension Cable - Black In Stock £8.26
BG5R C2G 7m DB9 M/F Extension Cable - Black In Stock £10.84
BG5R C2G 5m Cat6 550 MHz Snagless Patch Cable - Grey In Stock £2.23
BG5R C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £3.21
BG5R C2G 10m Cat6 550 MHz Snagless Patch Cable - Black In Stock £11.80
BG5R C2G 2m Cat6a Shielded Patch - Blue In Stock £7.20
