APC Smart-UPS SC is the perfect protection for the IT resources of your growing business. Manageable and cost effective, APC Smart-UPS SC is designed for use by small and medium companies looking to protect networking equipment, providing both power and data-line protection. Included PowerChute Business Edition management software allows you to configure safe system shutdowns and take advantage of advanced UPS management features like automated risk assessments and runtime capacity calculations. (All major operating systems supported). Communications are through your server's standard serial port. When you are ready to take your business to the next level you can use the same software environment found on Smart-UPS SC to seamlessly manage other Smart-UPS models, allowing you to grow your IT infrastructure without having to replace your software or retrain your administrators. Built on the same standards as the award winning Smart-UPS UPS, the Smart-UPS SC is the UPS to start your business with.
Front-access servicing
Simplifies installation and UPS maintenance while minimizing space requirements -
Rack/Tower convertible
Protects the initial investment in the UPS when migrating from tower to rack-mount environment -
Multiple mounting methods
Allows for standardization on one product for use in different environments
- APC Smart-UPS SC 450VA - UPS - 280 Watt - 450 VA
- UPS - rack-mountable
- Rack Size
- 1U
- 10.2 kg
- Input Voltage
- AC 230 V
- Output Voltage
- AC 230 V ± 5%
- Power Capacity
- 280 Watt / 450 VA
- Input Connectors
- 1 x power IEC 60320 C14
- Output connectors
- 4 x power IEC 60320 C13
- Battery
- Lead Acid
- Battery Form Factor
- Plug-in module
- Run Time (Up To)
- 5.9 min at full load
- Networking
- RS-232
- Grey
- 43.2 cm x 38.3 cm x 4.4 cm
- 2-year warranty
- Designed For
- P/N: AR106SH6, AR109SH6, AR112SH6, AR3003, AR3003SP, AR3006, AR3006SP, AR3103, AR3103SP, AR3106, AR3106SP, AR3140G, AR3340G, AR3357X674, AR4018SP, AR4018SPX429, AR4018SPX431, AR4018SPX432, AR4018X429, AR4024IX431, AR4024SP, AR4024SPX429, AR4024SPX431, AR4024SPX432, AR4038IX432, NBWL0356A
- Battery Enclosure Type
- Plug-in module
- Height (Rack Units)
- 1U
- Grey
- UPS Technology
- Line interactive
- Input Voltage
- AC 230 V
- Input Voltage Range
- AC 160 - 286 V
- Input Voltage Range (Adjustable)
- AC 151 - 302 V
- Frequency Provided
- 47 - 63 Hz
- Frequency Required
- 50/60 Hz
- Input Connectors
- Power Output Connectors Details
- Output Voltage
- AC 230 V ± 5% - 47 - 63 Hz
- Power Capacity
- 280 Watt / 450 VA
- Dataline Surge Protection
- Network/phone line - RJ-45/RJ-11
- Output Waveform
- Stepped approximation to a sinewave
- Surge Suppression
- Surge Energy Rating
- 320 Joules
- Technology
- Lead Acid
- Run Time (Up To)
- Remote Management Interface
- RS-232
- 1 x management (RS-232) - 9 pin D-Sub (DB-9)
- Cables Included
- Serial cable - external
- Rack Mounting Kit
- Included
- Audible alarm, LED display
- C-Tick, GOST, PCBC, VDE, EN 50091-2
- Software Included
- APC PowerChute Business Edition
- Limited warranty - 2 years
- 0 °C
- 40 °C
- 0 - 95%
- 43.2 cm
- 38.3 cm
- 4.4 cm
- 10.2 kg
- Designed For
- P/N: ACCS1000, ACCS1001, ACCS1002, ACCS1003, ACCS1004, ACCS1005, ACCS1006, ACCS1007, ACDC1015, ACDC1016, ACDC1017, ACDC1019, ACDC1020, ACDC1021, ACDC2513, ACF001, ACF002, ACF003, ACF101BLK, ACF102BLK, ACF201BLK, ACF400, ACF600, AP5017, AP5602, AP5606, AP5607, AP5616, AP92200, AP9290, AR100, AR100HD, AR106SH6, AR109SH6, AR112SH6, AR202, AR203A, AR204A, AR2101, AR2102BLK, AR2144BLK, AR2145BLK, AR2200, AR2280, AR2400, AR2400FP1, AR2401, AR2407, AR2480, AR2487, AR2487G, AR2500, AR2507, AR2580, AR2587, AR2900, AR2901, AR3000, AR3003, AR3003SP, AR3006, AR3006SP, AR3100, AR3100G, AR3100SP, AR3100SP1, AR3100SP2, AR3100TAA, AR3100W, AR3100X609, AR3100X610, AR3100X617, AR3101, AR3103, AR3103SP, AR3104SP1, AR3105, AR3105SP, AR3105W, AR3106, AR3106SP, AR3107, AR3107G, AR3107SP, AR3107X609, AR3107X610, AR3107X617, AR3130, AR3140, AR3140G, AR3140W, AR3150, AR3150SP, AR3150SP1, AR3150SP2, AR3150W, AR3150X609, AR3150X610, AR3150X617, AR3155, AR3155SP, AR3155W, AR3157, AR3157SP, AR3157X609, AR3157X610, AR3157X617, AR3200, AR3300, AR3300G, AR3300SP, AR3300W, AR3300X609, AR3300X610, AR3300X617, AR3305, AR3305SP, AR3305W, AR3307, AR3307SP, AR3307W, AR3307X609, AR3307X610, AR3307X617, AR3340, AR3340G, AR3340W, AR3347, AR3350, AR3350SP, AR3350W, AR3350X609, AR3350X610, AR3350X617, AR3355, AR3355SP, AR3355W, AR3357, AR3357SP, AR3357X609, AR3357X610, AR3357X617, AR3357X674, AR3810, AR3812, AR3814, AR4018, AR4018A, AR4018I, AR4018IA, AR4018IX429, AR4018IX431, AR4018IX432, AR4018SP, AR4018SPX429, AR4018SPX431, AR4018SPX432, AR4018X429, AR4018X431, AR4018X432, AR4024, AR4024A, AR4024I, AR4024IA, AR4024IX429, AR4024IX431, AR4024IX432, AR4024SP, AR4024SPX429, AR4024SPX431, AR4024SPX432, AR4024X429, AR4024X431, AR4024X432, AR4038, AR4038A, AR4038I, AR4038IA, AR4038IX429, AR4038IX431, AR4038IX432, AR4038X429, AR4038X431, AR4038X432, AR7007, AR7050, AR7057, AR8135BLK, NBWL0356A
APC Battery Replacement Kit for PS250I, PS450I | In Stock | £133.29 |
APC Power Cord IEC 320 C13 to IEC 320 C14 | In Stock | £28.68 |
APC Interface Cable for Win NT/2000/98 | In Stock | £36.33 |
APC Pwr Cord, 10A, 230V, C14 to UK rec | In Stock | £51.51 |
APC Rack PDU, Basic, Zero U, 10A,2 | In Stock | £263.71 |
APC NETSHELTER SX 24U | In Stock | £1,151.52 |
APC Power Cable (pack of 6) 1.22m | In Stock | £87.33 |
APC Power Cord Kit (6 ea) - Locking - C13 to C14 - 1.8m | In Stock | £127.65 |
APC Service Pack 1 Year Warranty Extension | In Stock | £42.84 |
APC Service Pack 3 Year Warranty Extension | In Stock | £97.06 |
APC Basic Rack PDU AP6015A Power Distribution Unit | In Stock | £60.21 |
APC Switched Rack PDU AP7920B Power Distribution Strip AC 200/20 | In Stock | £644.38 |
Customer reviews
Write a review for the APC Smart-UPS SC 450VA 1U here!
Q: about noise
Reviewed by boolve. Review Posted 27/01/2008
I have question. Are this UPS build in fan? All rack mount APC UPS with noise level ~ 34dBa. All time this fan is on?
- Overall
- Ease of use
- Value for money
The opinions expressed in this reviews section are those of our customers and not of BT Business Direct. Nothing contained herein amends BT Business Direct’s terms and conditions.
