Customize UPS capabilities with management cards. Automatic internal bypass supplies utility power to the connected loads in the event of a UPS power overload or fault. Scalable run time allows additional run time to be quickly added as needed. Intelligent battery management maximizes battery performance, life, and reliability through intelligent, precision charging. Hot-swappable batteries ensure clean, uninterrupted power to protected equipment while batteries are being replaced.
SmartSlot
Customize UPS capabilities with management cards. -
Supplies utility power to the connected loads in the event of a UPS power overload or fault. -
Scalable run time
Scalable run time allows additional run time to be quickly added as needed. -
Maximizes battery performance, life, and reliability through intelligent, precision charging. -
Ensure clean, uninterrupted power to protected equipment while batteries are being replaced. -
Automatic restart of loads after UPS shutdown
Automatically starts up the connected equipment upon the return of utility power. -
Temperature-compensated battery charging
Prolongs battery life by regulating the charge voltage according to battery temperature. -
Network manageable
Provides remote power management of the UPS over the network. -
LED status indicators
Quickly understand unit and power status with visual indicators. -
Serial connectivity
Provides management of the UPS via a serial port. -
Plug-and-Play external batteries
Ensure clean, uninterrupted power to the loads when adding extra runtime to the UPS. -
Rack / tower convertible
Protects the initial investment in the UPS when migrating from tower to rack-mount environment. -
Predictive failure notification
Provides early-warning fault analysis ensuring proactive component replacement. -
Disconnected battery notification
Warns when a battery is not available to provide backup power. -
Audible alarms
Actively let you know if the unit is on battery, if the battery is low or if there is an overload condition. -
Power conditioning
Protects connected loads from surges, spikes, lightning, and other power disturbances. -
Cold-start capable
Provides temporary battery power when the utility power is out. -
Resettable circuit breakers
Enable a quick recovery from overload events.
- APC Smart-UPS RT 3000VA RM - UPS - 2.1 kW - 3000 VA
- UPS - rack-mountable
- Rack Size
- 3U
- 54.6 kg
- Input Voltage
- AC 220/230/240 V
- Output Voltage
- AC 220/230/240 V ± 3%
- Power Capacity
- 2.1 kW / 3000 VA
- Input Connectors
- 3 x power IEC 60320 C20, power BS 1363, power CEE 7/7
- Output connectors
- 8 x power IEC 60320 C13 , 2 x power IEC 60320 C19
- Battery
- Lead Acid
- Battery Form Factor
- Plug-in module
- Batteries Qty
- 1
- Run Time (Up To)
- 14.1 min at full load
- Networking
- RS-232
- Black
- 43.2 cm x 66 cm x 13 cm
- 2-year warranty
- Battery Enclosure Type
- Plug-in module
- Height (Rack Units)
- 3U
- Black
- UPS Technology
- On-line
- Input Voltage
- AC 220/230/240 V
- Input Voltage Range
- AC 160 - 280 V
- Input Voltage Range (Adjustable)
- AC 100 - 280 V
- Frequency Provided
- 50/60 Hz
- Frequency Required
- 50/60 Hz
- Input Connectors
- Power Output Connectors Details
- Output Voltage
- AC 220/230/240 V ± 3% - 50/60 Hz
- Power Capacity
- 2.1 kW / 3000 VA
- Output Waveform
- Sinewave
- Surge Suppression
- Surge Energy Rating
- 480 Joules
- Quantity
- 1
- Technology
- Lead Acid
- Run Time (Up To)
- Recharge Time
- 2.5 hours
- Remote Management Interface
- RS-232
- 1 x management (RS-232)
- Expansion Slots
- 1 (total) / 1 (free) x SmartSlot
- Cables Included
- Power cable 2.4 m , Serial cable - external
- Rack Mounting Kit
- Included
- Audible alarm, emergency power off, internal bypass, LED indicators
- CSA, VCCI, C-Tick, BSMI, GOST, EN 60950, EN 61000-3-2, JEON, UL 1778, VDE, EN55022 Class A, EN 50091-2, EN 50091-1
- Software Included
- Drivers & Utilities
- Limited warranty - 2 years
- 0 °C
- 40 °C
- 0 - 95%
- Sound Emission
- 55 dBA
- 43.2 cm
- 66 cm
- 13 cm
- 54.6 kg
- Shipping Width
- 60.3 cm
- Shipping Depth
- 98 cm
- Shipping Height
- 34.7 cm
- Shipping Weight
- 63.6 kg
APC NETSHELTER SX 24U | In Stock | £1,151.52 |
