APC Smart-UPS C LCD AC 230 V - 900 Watt - 1500VA USB
Quicklinx: DRTTWS00 Mfr#: SMC1500IC
Type: UPS
Power Rating: 900Watt
28 in stock
£447.53 ex VAT
£537.03 inc VAT
APC Smart-UPS C 1500VA LCD. AC 230 V, 900 Watt, 1500 VA ,USB output connectors: 8. In black with APC SmartConnect.
  • Pure sine wave output on battery
    Simulates utility power to provide the highest degree of compatibility for active PFC (power factor corrected) servers and sensitive electronics
  • Cold-start capable
    Provides temporary battery power when the utility power is out
  • LCD Status Display
    Provides key UPS status at a glance. Multiple status indicators with load and battery bar graphs
  • Temperature-compensated battery charging
    Prolongs battery life by regulating the charge voltage according to battery temperature
  • Green mode
    Patent-pending operating mode that bypasses unused electrical components in good power conditions to achieve very high operating efficiency without sacrificing any protection
  • High online efficiency
    Reduces utility costs, generates less heat
  • SmartConnect
    Innovative, easy to use remote monitoring feature that provides automatic notifications, firmware updates, and advanced support services
APC Smart-UPS C 1500VA LCD - UPS - 900 Watt - 1500 VA - with APC SmartConnect
UPS - external
24.09 kg
Input Voltage
AC 230 V
Output Voltage
AC 230 V ± 5%
Power Capacity
900 Watt / 1500 VA
Input Connectors
1 x power IEC 60320 C14
Output connectors
8 x power IEC 60320 C13
Lead Acid
Batteries Qty
1
Run Time (Up To)
4 min at full load
USB
17.1 cm x 43.9 cm x 21.9 cm
Bundled with
APC SmartConnect
UPS - external
Bundled with
APC SmartConnect
UPS Technology
Line interactive
Input Voltage
AC 230 V
Input Voltage Range
AC 180 - 287 V
Input Voltage Range (Adjustable)
AC 170 - 300 V
Frequency Provided
50/60 Hz ± 3Hz
Frequency Required
50/60 Hz ± 3%
Input Connectors
Output Voltage
AC 230 V ± 5% - 50/60 Hz
Power Capacity
900 Watt / 1500 VA
Output Waveform
Sinewave
Surge Suppression
Surge Energy Rating
459 Joules
Circuit Protection
Circuit breaker
Quantity
1
Lead Acid
Run Time (Up To)
4 min at full load , 11 min at half load
Recharge Time
3 hours
Switchover Time
6 ms
Maintenance free, sealed, leak-proof
Remote Management Interface
USB
1 x management - RJ-45 , 1 x USB - 4 pin USB Type A
Audible alarm, LCD display, Automatic Voltage Regulation (AVR), cold-start function, automatic shut down reset, automatic self-test, hot-swappable batteries, Green Function, auto restart, temperature-compensated battery charging
CSA, C-Tick, GOST, UL 1778, VDE
0 - 95%
Sound Emission
45 dBA
17.1 cm
43.9 cm
21.9 cm
24.09 kg
Shipping Width
32.8 cm
Shipping Depth
59.5 cm
Shipping Height
37.6 cm
Shipping Weight
27.23 kg
Type: UPS
Brand: APC
Price Range Ex VAT: 300 - 500
