Green mode bypasses unused electrical components in good power conditions to achieve very high operating efficiency without sacrificing any protection. Pure sine wave output on battery simulates utility power to provide a high degree of compatibility for active PFC (power factor corrected) servers and sensitive electronics. LCD status display provides key UPS status at a glance. It has multiple status indicators with load and battery bar graphs. Cold-start capable provides temporary battery power when the utility power is out. Temperature-compensated battery charging prolongs battery life by regulating the charge voltage according to battery temperature.
Simulates utility power to provide the highest degree of compatibility for active PFC (power factor corrected) servers and sensitive electronics -
Cold-start capable
Provides temporary battery power when the utility power is out -
LCD Status Display
Provides key UPS status at a glance. Multiple status indicators with load and battery bar graphs -
Prolongs battery life by regulating the charge voltage according to battery temperature -
Green mode
Patent-pending operating mode that bypasses unused electrical components in good power conditions to achieve very high operating efficiency without sacrificing any protection -
High online efficiency
Reduces utility costs, generates less heat
- APC Smart-UPS C 1000VA 2U LCD - UPS - 600 Watt - 1000 VA
- UPS - rack-mountable
- Rack Size
- 2U
- 20.52 kg
- Input Voltage
- AC 230 V
- Output Voltage
- AC 230 V ± 5%
- Power Capacity
- 600 Watt / 1000 VA
- Input Connectors
- 1
- Output connectors
- 4 x power IEC 60320 C13 , 1 x power
- Battery
- Lead Acid
- Battery Form Factor
- Internal
- Batteries Qty
- 1
- Run Time (Up To)
- 6 min at full load
- Networking
- USB
- Black
- 43.2 cm x 40.6 cm x 8.9 cm
- 2 years warranty
- Battery Enclosure Type
- Internal
- Height (Rack Units)
- 2U
- Black
- UPS Technology
- Line interactive
- Input Voltage
- AC 230 V
- Input Voltage Range
- AC 180 - 287 V
- Input Voltage Range (Adjustable)
- AC 170 - 300 V
- Frequency Provided
- 57 - 63 Hz
- Frequency Required
- 50/60 Hz
- Input Connectors
- 1
- Power Output Connectors Details
- Output Voltage
- AC 230 V ± 5% - 57 - 63 Hz
- Power Capacity
- Output Waveform
- Sinewave
- Surge Suppression
- Surge Energy Rating
- 459 Joules
- Circuit Protection
- Circuit breaker
- Quantity
- 1
- Technology
- Lead Acid
- Run Time (Up To)
- 16 min at half load , 6 min at full load
- Recharge Time
- 3 hours
- Remote Management Interface
- USB
- 1 x management (USB) - 4 pin USB Type B
- Cables Included
- Power cable , USB cable - external
- Rack Mounting Kit
- Included
- Audible alarm, LCD display, Automatic Voltage Regulation (AVR), cold-start function, automatic shut down reset, automatic self-test, hot-swappable batteries
- C-Tick, GOST, UL 1449, VDE, RoHS, REACH
- Software Included
- Drivers & Utilities
- Limited warranty - parts and labour - 2 years
- 0 °C
- 40 °C
- 0 - 95%
- Sound Emission
- 42 dBA
- 43.2 cm
- 40.6 cm
- 8.9 cm
- 20.52 kg
- Shipping Width
- 59.4 cm
- Shipping Depth
- 58.4 cm
- Shipping Height
- 24.1 cm
- Shipping Weight
- 22.33 kg
