APC Smart-UPS 5000VA
Quicklinx: 52W9WS00 Mfr#: SUA5000RMI5U
Type: UPS
Power Rating: 4kW
Hurry, only 1 left in stock!
£2,665.12 ex VAT
£3,198.14 inc VAT
APC Smart-UPS protects your data by supplying reliable, network-grade power in either traditional Tower or Rack-optimized form factors for space constrained business critical applications. Award winning APC Smart-UPS is the perfect UPS for protecting business critical fileservers (Intel or UNIX based), minicomputers, network switches and hubs, Point of Sale, retail/bank back office and ATMs. Rack Mount versions are the choice for rack optimized servers, server appliances, blade servers, other blade devices and rack-mounted network switches and hubs.
  • Audible alarms
    Provides notification of changing utility power and UPS power conditions
  • Automatic self-test
    Periodic battery self-test ensures early detection of a battery that needs to be replaced
  • Resettable circuit breakers
    Enables a quick recovery from overload events
  • Cold-start capable
    Provides temporary battery power when the utility power is out
  • Temperature-compensated battery charging
    Prolongs battery life by regulating the charge voltage according to battery temperature
  • SmartSlot
    Customize UPS capabilities with management cards
  • Safety-agency approved
    Ensures the product has been tested and approved to work safely with the connected service provider equipment and within the specified environment
  • Network manageable
    Provides remote power management of the UPS over the network
  • Hot-swappable batteries
    Ensures clean, uninterrupted power to protected equipment while batteries are being replaced
  • Boost and Trim Automatic Voltage Regulation (AVR)
    Gives higher application availability by correcting low and high voltage conditions without using the battery (not available on all models)
  • Serial connectivity
    Provides management of the UPS via a serial port
  • Disconnected battery notification
    Warns when a battery is not available to provide backup power
  • Adjustable voltage-transfer points
    Maximizes useful battery life by widening the input voltage window or tightening the output voltage regulation
  • Rack/Tower convertible
    Protects the initial investment in the UPS when migrating from tower to rack-mount environment
APC Smart-UPS - UPS - 4 kW - 5000 VA
UPS - external
Rack Size
5U
97.7 kg
Input Voltage
AC 230 V
Output Voltage
AC 220/230/240 V ± 5%
Power Capacity
4 kW / 5000 VA
Input Connectors
1 x hardwire 3-wire
Output connectors
8 x power IEC 60320 C13 , 2 x power IEC 60320 C19
Lead Acid
Battery Form Factor
Internal
Batteries Qty
2
Run Time (Up To)
9.4 min at full load
Ethernet 10/100, RS-232
Remote Management Protocol
SNMP, Telnet, HTTP
48.3 cm x 66 cm x 22.2 cm
UPS - external
Battery Enclosure Type
Internal
Height (Rack Units)
5U
UPS Technology
Line interactive
Input Voltage
AC 230 V
Input Voltage Range
AC 160 - 286 V
Input Voltage Range (Adjustable)
AC 151 - 302 V
Frequency Provided
50/60 Hz
Frequency Required
50/60 Hz
Input Connectors
1 x hardwire 3-wire
Output Voltage
AC 220/230/240 V ± 5% - 50/60 Hz
Power Capacity
4 kW / 5000 VA
Output Waveform
Sinewave
Surge Suppression
Surge Energy Rating
480 Joules
Quantity
2
Lead Acid
Run Time (Up To)
Recharge Time
3 hours
Remote Management Interface
SNMP, Telnet, HTTP
1 x management (RS-232) - 9 pin D-Sub (DB-9) , 1 x management (Ethernet) - RJ-45
Expansion Slots
1 (total) / 0 (free) x SmartSlot
Serial cable - external
Rack Mounting Kit
Included
Audible alarm, LED indicators, noise filtering
C-Tick, GOST, GS, VDE, EN 50091-2, EN 50091-1
Software Included
Drivers & Utilities
0 - 95%
Sound Emission
53 dBA
48.3 cm
66 cm
22.2 cm
97.7 kg
Shipping Width
61 cm
Shipping Depth
76.2 cm
Shipping Height
63.5 cm
Shipping Weight
107 kg
52W9 APC Interface Cable for Win NT/2000/98 In Stock £29.60
52W9 APC 2-Post Mounting Kit for Smart-UPS In Stock £122.39
52W9 APC Replacement Battery Cartridge RBC55 In Stock £299.78
52W9 APC Network Management Card With 2 Environment Monitor In Stock £346.13
52W9 APC UPS Network Management Card 2 In Stock £214.26
52W9 APC NETSHELTER SX 24U In Stock £874.27
Resources
Type: UPS
Power Rating: 4kW
Brand: APC
Price Range Ex VAT: 1500+
