APC Smart-UPS 3000VA LCD RM 2U 230V
Quicklinx: 7KRLWS00 Mfr#: SMT3000RMI2U
Type: UPS
Power Rating: 2.7kW
£1,400.42 ex VAT
£1,680.50 inc VAT
Wide input voltage range is designed for harsh electrical environments to save battery life. LED indicators provide easy-to-read status of the unit and utility power conditions. Boost and trim Automatic Voltage Regulation (AVR) eliminates voltage fluctuations as a source of AV signal degradation and component power-supply stress. Green mode bypasses unused electrical components in good power conditions to achieve very high operating efficiency without sacrificing any protection. Energy meter provides actual kilowatt hours of usage for energy conscious users. Intuitive LCD interface provides clear and accurate information with the ability to configure the UPS locally with easy to use navigation keys.
  • User-replaceable batteries
    Increases availability by allowing a trained user to perform upgrades and replacements of the batteries reducing Mean Time to Repair (MTTR)
  • Audible alarms
    Provides notification of changing utility power and UPS power conditions
  • Automatic self-test
    Periodic battery self-test ensures early detection of a battery that needs to be replaced
  • Intelligent battery management
    Maximizes battery performance, life, and reliability through intelligent, precision charging
  • Pure sine wave output on battery
    Simulates utility power to provide the highest degree of compatibility for active PFC (power factor corrected) servers and sensitive electronics
  • Cold-start capable
    Provides temporary battery power when the utility power is out
  • Temperature-compensated battery charging
    Prolongs battery life by regulating the charge voltage according to battery temperature
  • Green mode
    Patent-pending operating mode that bypasses unused electrical components in good power conditions to achieve very high operating efficiency without sacrificing any protection
  • High online efficiency
    Reduces utility costs, generates less heat
  • Intuitive LCD interface
    Provides clear and accurate information in multiple languages with the ability to configure the UPS locally with easy to use navigation keys
  • Predictive replace battery date
    Dynamically provides the month and year when battery replacement is recommended to aide in long term maintenance planning
  • Single switched outlet group
    Single outlet group that may be controlled separately from the UPS for discrete reboot of hung devices, sequenced on/off and non-critical load shedding
  • Energy meter
    Provides actual kilowatt hours of usage for energy conscious users
  • Battery failure notification
    Provides early-warning fault analysis on batteries enabling timely preventive maintenance
  • Safety-agency approved
    Ensures the product has been tested and approved to work safely with the connected service provider equipment and within the specified environment
  • Network manageable
    Provides remote power management of the UPS over the network
  • Hot-swappable batteries
    Ensures clean, uninterrupted power to protected equipment while batteries are being replaced
  • Boost and Trim Automatic Voltage Regulation (AVR)
    Gives higher application availability by correcting low and high voltage conditions without using the battery (not available on all models)
  • Serial connectivity
    Provides management of the UPS via a serial port
  • Disconnected battery notification
    Warns when a battery is not available to provide backup power
  • USB connectivity
    Provides management of the UPS via a USB port (not available on all models)
  • Adjustable voltage-transfer points
    Maximizes useful battery life by widening the input voltage window or tightening the output voltage regulation
  • Adjustable voltage sensitivity
    Provides the ability to adapt the UPS for optimal performance in specific power environments or generator applications
  • Automatic restart of loads after UPS shutdown
    Automatically starts up the connected equipment upon the return of utility power
  • Sequenced network shutdown and reboot
    Customize network shutdown and reboot sequence of connected servers and UPSs
  • Outlet group control
    Turn on/off, reboot or shut down select outlet groups to save dispatching technicians to remote locations (for UPSs with switched outlet groups)
  • Predicitive failure notification
    Provides early-warning fault analysis ensuring proactive component replacement
  • LED Indicators
    Provide easy-to-read status of the unit and utility power conditions
  • Wide input voltage range
    Designed for harsh electrical environments to save battery life
  • Frequency and voltage regulation
    Gives higher application availability by correcting poor frequency and voltage conditions without using the battery
  • StruxureWare Data Center Expert compatible
    Enables centralized management via StruxureWare Data Center Expert
APC Smart-UPS 3000 LCD - UPS - 2.7 kW - 3000 VA
UPS - rack-mountable
Rack Size
2U
44.3 kg
Input Voltage
AC 220/230/240 V
Output Voltage
AC 220/230/240 V
Power Capacity
2.7 kW / 3000 VA
Input Connectors
Power IEC 60320 C20, power CEE 7/7, power BS 1363A
Output connectors
8 x power IEC 60320 C13 , 1 x power IEC 60320 C19
Lead Acid
Run Time (Up To)
3.2 min at full load
RS-232, USB
48 cm x 68.3 cm x 8.6 cm
3-year warranty
Height (Rack Units)
2U
UPS Technology
Line interactive
Input Voltage
AC 220/230/240 V
Input Voltage Range
AC 160 - 286 V
Input Voltage Range (Adjustable)
AC 151 - 299 V
Frequency Required
50/60 Hz
Input Connectors
Output Voltage
AC 220/230/240 V
Power Capacity
2.7 kW / 3000 VA
Output Waveform
Sinewave
Surge Suppression
Surge Energy Rating
320 Joules
Circuit Protection
Circuit breaker
Lead Acid
Run Time (Up To)
3.2 min at full load , 11.5 min at half load
Recharge Time
3 hours
Remote Management Interface
RS-232, USB
1 x USB , 1 x serial
Expansion Slots
1 (total) / 1 (free) x SmartSlot
Serial cable , USB cable , Power cable - integrated - 2 m
Rack Mounting Kit
Included
Audible alarm, LCD display, Automatic Voltage Regulation (AVR), LED indicators
C-Tick, GOST, EN 60950, GS, VDE, IEC 62040-1-1, RoHS Exemption 7b, IEC 62040-2, IRAM, WEEE, REACH
Software Included
Drivers & Utilities
Limited warranty - 3 years , Limited warranty - batteries - 2 years
0 - 95%
Sound Emission
55 dBA
48 cm
68.3 cm
8.6 cm
44.3 kg
Shipping Width
60 cm
Shipping Depth
98 cm
Shipping Height
25.4 cm
Shipping Weight
51.7 kg
Type: UPS
Power Rating: 2.7kW
Brand: APC
Price Range Ex VAT: 1000 - 1500
