APC Smart-UPS 3000VA LCD 230V
Quicklinx: 73G1WS00 Mfr#: SMT3000I
Patent-pending operating mode that bypasses unused electrical components in good power conditions to achieve very high operating efficiency without sacrificing any protection. Provides actual kilowatt hours of usage for energy conscious users.
  • Cold-start capable
    Provides temporary battery power when the utility power is out.
  • Energy meter
  • Green mode
  • High online efficiency
    Reduces utility costs, generates less heat.
  • Intelligent Card Slot
    Customize UPS capabilities with management cards.
  • Intuitive LCD interface
    Provides clear and accurate information in multiple languages with the ability to configure the UPS locally with easy to use navigation keys.
  • Predictive replace battery date
    Dynamically provides the month and year when battery replacement is recommended to aide in long term maintenance planning.
  • Pure sine wave output on battery
    Simulates utility power to provide the highest degree of compatibility for active PFC (power factor corrected) servers and sensitive electronics.
  • Sequenced network shutdown and reboot
    Customize network shutdown and reboot sequence of connected servers and UPSs.
  • Single switched outlet group
    Single outlet group that may be controlled separately from the UPS for discrete reboot of hung devices, sequenced on/off and non-critical load shedding.
  • StruxureWare Data Center Expert compatible
    Enables centralized management via StruxureWare Data Center Expert.
  • Temperature-compensated battery charging
    Prolongs battery life by regulating the charge voltage according to battery temperature.
APC Smart-UPS 3000 LCD - UPS - 2700 Watt - 3000 VA
UPS - external
52.5 kg
Input Voltage
AC 230 V
Output Voltage
AC 220/230/240 V ± 5%
Power Capacity
2700 Watt / 3000 VA
Input Connectors
Power IEC 60320 C20, power BS 1363, power CEE 7/7
Output connectors
8 x power IEC 60320 C13 , 1 x power IEC 60320 C19
Lead Acid
Run Time (Up To)
5.5 min at full load
RS-232, USB
19.7 cm x 54.4 cm x 43.5 cm
3-year warranty
UPS - external
UPS Technology
Line interactive
Input Voltage
AC 230 V
Input Voltage Range
AC 160 - 285 V
Input Voltage Range (Adjustable)
AC 151 - 302 V
Frequency Provided
47 - 53 / 57 - 63 Hz
Frequency Required
50/60 Hz
Input Connectors
Output Voltage
AC 220/230/240 V ± 5% - 47 - 53 / 57 - 63 Hz
Power Capacity
2700 Watt / 3000 VA
Output Waveform
Sinewave
Surge Suppression
Surge Energy Rating
365 Joules
Circuit Protection
Circuit breaker
Lead Acid
Run Time (Up To)
5.5 min at full load , 13.6 min at half load
Recharge Time
3 hours
Remote Management Interface
RS-232, USB
1 x management (RS-232) - 9 pin D-Sub (DB-9) , 1 x USB , 1 x EPO (emergency power off)
Expansion Slots
1 SmartSlot
Serial cable - external , USB cable - external
Audible alarm, emergency power off, LCD display, noise filtering
C-Tick, UL 1449, VDE, EN 50091-2, RoHS Exemption 7b, RoHS, EN 50091-1, REACH
Limited warranty - 3 years , Limited warranty - batteries - 2 years
0 - 95%
Sound Emission
53 dBA
19.7 cm
54.4 cm
43.5 cm
52.5 kg
Shipping Width
38.1 cm
Shipping Depth
76.2 cm
Shipping Height
69.9 cm
Shipping Weight
63.7 kg
