Your basket is empty
APC Smart-UPS 3000 LCD UPS 2.7 kW 3000 VA
Quicklinx: CD46WS00 Mfr#: SMT3000RM2U
Power Rating: 2.7kW
£1,398.43 ex VAT
£1,678.11 inc VAT
Intelligent line interactive power protection ideal for core business servers and mid-range network gear. Smart-UPS is trusted by millions of IT professionals throughout the world to protect equipment and critical data by supplying reliable, network-grade power reliably and efficiently.
APC by Schneider Electric's Smart-UPS is the most popular uninterruptible power supply (UPS) in the world for servers and other network devices such as switches, routers workstations and point-of-sale devices. Available in either traditional tower, rack optimized, or extended run convertible form factor (750va-3000va). The world's most popular network and server UPS.
Trusted by millions to protect critical data and equipment from power problems its proven line interactive design supplies clean and reliable network-grade power over a wide range of utility conditions. Conditions include surges, spikes, brownouts, blackouts and other transient conditions that can cause costly downtime, data loss or hardware damage.
Smart-UPS are known for their intelligence, monitoring and control capability. Users can actively manage power to their critical devices using an intuitive and interactive display, through the supplied PowerChute Business edition software or remotely with optional network management cards that plug directly into the unit's Smart-slot interface.
Patent pending "green" mode provides optimum reliability and efficiency of > 97% which saves utility and cooling costs without compromising availability.
Advanced battery management provides Temperature compensated charging which extends life and advanced algorithms proactively recommend battery replacement date. In addition, Switched Outlet Groups can allow users to Reboot Hung devices, shed non-critical loads to conserve runtime, and set sequenced startup/turn off.
APC Smart-UPS 3000 LCD - UPS - 2.7 kW - 3000 VA
UPS - rack-mountable
Rack Size
2U
44.3 kg
Input Voltage
AC 120 V
Output Voltage
120 V
Power Capacity
2.7 kW / 3000 VA
Input Connectors
1 x power NEMA L5-30
Output connectors
6 x power NEMA 5-15 , 2 x power NEMA 5-20
Lead Acid
Battery Form Factor
Plug-in module
Batteries Qty
1
Run Time (Up To)
3.4 min at full load
RS-232, USB
48 cm x 68.3 cm x 8.6 cm
3 years warranty
Battery Enclosure Type
Plug-in module
Height (Rack Units)
2U
UPS Technology
Line interactive
Input Voltage
AC 120 V
Input Voltage Range
AC 82 - 144 V
Input Voltage Range (Adjustable)
AC 75 - 154 V
Frequency Required
50/60 Hz
Input Connectors
Output Voltage
120 V
Power Capacity
2.7 kW / 3000 VA
Output Waveform
Sinewave
Surge Suppression
Surge Energy Rating
459 Joules
Quantity
1
Lead Acid
Run Time (Up To)
3.4 min at full load , 11.7 min at half load
Recharge Time
3 hours
Remote Management Interface
RS-232, USB
1 x management (USB) , 1 x management (RS-232)
Expansion Slots
1 SmartSlot
Serial cable - external , USB cable - external , Power cable - integrated - 2.4 m
Rack Mounting Kit
Included
Equipment Protection Value
150000 US Dollars
Audible alarm, LCD display, Automatic Voltage Regulation (AVR), LED indicators
CSA, UL 1778, RoHS Exemption 7b, FCC Part 15 A, REACH
Software Included
Drivers & Utilities
Limited warranty - 3 years , Limited warranty - batteries - 2 years
0 - 95%
Sound Emission
55 dBA
48 cm
68.3 cm
8.6 cm
44.3 kg
Shipping Width
60 cm
Shipping Depth
98 cm
Shipping Height
25.4 cm
Shipping Weight
51.7 kg
Power Rating: 2.7kW
Brand: APC
Price Range Ex VAT: 1000 - 1500
