APC Smart-UPS XL protects your data by supplying reliable, network-grade power with scalable run-time in tower and rack mount form factors. With optional, matching battery packs, run-time can be easily extended and optimized for the application. APC understands long run-time requirements, so Smart-UPS XLs can be configured with up to 10 additional battery packs - for run-times exceeding 24 hours, if necessary.
Advanced battery management included
Embedded monitoring at the cell, module, and cabinet level provides a clear picture of battery runtime and health, with the added benefits of predictable, consistent runtime performance and stable cell health. -
Maintenance-free battery
Maintenance-free sealed battery with suspended electrolyte. It's also leakproof.
- APC Smart-UPS XL 24V Battery Pack - external battery pack - Lead Acid
- External battery pack
- 31.4 kg
- Battery
- Lead Acid
- Battery Form Factor
- External
- Black
- 17 cm x 43.9 cm x 21.6 cm
- 2-year warranty
- Designed For
- P/N: SUA1000UXI, SUA1000UXICH, SUA1000XL, SUA1000XLI, SUA500XLJ, SUA750XL, SUA750XLI, SUA750XLX320
- Battery Enclosure Type
- External
- Black
- Technology
- Lead Acid
- Voltage Provided
- 24 V
- Limited warranty - parts and labour - 2 years
- 0 °C
- 40 °C
- Min Storage Temperature
- -15 °C
- Max Storage Temperature
- 45 °C
- 0 - 95%
- Humidity Range Storage
- 0 - 95%
- 17 cm
- 43.9 cm
- 21.6 cm
- 31.4 kg
- Designed For
