APC Smart UPS 2200VA LCD RM 2U 230
Quicklinx: F0G2WS00 Mfr#: SMT2200RMI2UC
Type: UPS
Power Rating: 1980Watt
10 in stock
£1,105.71 ex VAT
£1,326.85 inc VAT
Marketing description is not available.
  • Pure sine wave output on battery
    Simulates utility power to provide the highest degree of compatibility for active PFC (power factor corrected) servers and sensitive electronics
  • Cold-start capable
    Provides temporary battery power when the utility power is out
  • Temperature-compensated battery charging
    Prolongs battery life by regulating the charge voltage according to battery temperature
  • Green mode
    Patent-pending operating mode that bypasses unused electrical components in good power conditions to achieve very high operating efficiency without sacrificing any protection
  • High online efficiency
    Reduces utility costs, generates less heat
  • Intuitive LCD interface
    Provides clear and accurate information in multiple languages with the ability to configure the UPS locally with easy to use navigation keys
  • Predictive replace battery date
    Dynamically provides the month and year when battery replacement is recommended to aide in long term maintenance planning
  • Single switched outlet group
    Single outlet group that may be controlled separately from the UPS for discrete reboot of hung devices, sequenced on/off and non-critical load shedding
  • SmartSlot
    Customize UPS capabilities with management cards
  • Energy meter
    Provides actual kilowatt hours of usage for energy conscious users
  • Sequenced network shutdown and reboot
    Customize network shutdown and reboot sequence of connected servers and UPSs
  • StruxureWare Data Center Expert compatible
    Enables centralized management via StruxureWare Data Center Expert
  • SmartConnect
    Innovative, easy to use remote monitoring feature that provides automatic notifications, firmware updates, and advanced support services
APC Smart-UPS SMT 2200VA LCD RM with SmartConnect - UPS - 1980 Watt - 2200 VA
UPS - rack-mountable / external
Rack Size
2U
42.31 kg
Input Voltage
AC 230 V
Output Voltage
AC 220/230/240 V
Power Capacity
1980 Watt / 2200 VA
Input Connectors
1 x power IEC 60320 C20
Output connectors
8 x power IEC 60320 C13 , 1 x power IEC 60320 C19
Lead Acid
Batteries Qty
1
Run Time (Up To)
5 min at full load
RS-232, USB
48 cm x 68.3 cm x 8.6 cm
Height (Rack Units)
2U
UPS Technology
On-line
Input Voltage
AC 230 V
Input Voltage Range
AC 160 - 286 V
Input Voltage Range (Adjustable)
AC 150 - 300 V
Frequency Provided
50/60 Hz
Frequency Required
50/60 Hz
Input Connectors
Output Voltage
AC 220/230/240 V 50/60 Hz
Power Capacity
1980 Watt / 2200 VA
Output Waveform
Sinewave
Surge Suppression
Quantity
1
Lead Acid
Maintenance free, sealed, leak-proof
Remote Management Interface
RS-232, USB
1 x management (RS-232) - RJ-45 , 1 x management (USB)
Expansion Slots
1 (total) / 1 (free) x SmartSlot
Audible alarm, LCD display
VDE, EN 62040-2, EAC, RCM, EN 62040-1
48 cm
68.3 cm
8.6 cm
42.31 kg
Type: UPS
Brand: APC
Price Range Ex VAT: 1000 - 1500
