APC Smart-UPS 1500VA LCD RM 1U 230V
Quicklinx: 9RVPWS00 Mfr#: SMT1500RMI1U
Type: UPS
Power Rating: 1000Watt
24 in stock
£718.09 ex VAT
£861.70 inc VAT
APC award-winning Smart-UPS is the most popular UPS in the world for servers, storage and networks. Trusted to protect critical data and equipment from power problems by supplying clean and reliable network-grade power. In addition to legendary reliability and manageability, Smart-UPS have extremely high efficiency at low, medium and high load levels making them ideal for today's multi-core or virtualized servers that have varying load consumption. Rack mounted Smart-UPS are ideal for powering blade or density optimized servers in a distributed power protection environment as the primary or redundant protection. Smart-UPS features a 16-segment LED display, extended range automatic voltage regulation (AVR), and pure sine wave output on battery.
  • Pure sine wave output on battery
    Simulates utility power to provide the highest degree of compatibility for active PFC (power factor corrected) servers and sensitive electronics
  • Cold-start capable
    Provides temporary battery power when the utility power is out
  • Temperature-compensated battery charging
    Prolongs battery life by regulating the charge voltage according to battery temperature
  • Green mode
    Patent-pending operating mode that bypasses unused electrical components in good power conditions to achieve very high operating efficiency without sacrificing any protection
  • High online efficiency
    Reduces utility costs, generates less heat
  • Intuitive LCD interface
    Provides clear and accurate information in multiple languages with the ability to configure the UPS locally with easy to use navigation keys
  • Predictive replace battery date
    Dynamically provides the month and year when battery replacement is recommended to aide in long term maintenance planning
  • SmartSlot
    Customize UPS capabilities with management cards
  • Energy meter
    Provides actual kilowatt hours of usage for energy conscious users
  • Multiple switched outlet groups
    Multiple outlet groups that may be controlled separately from the UPS for discrete reboot of hung devices, sequenced on/off and non-critical load shedding
  • High frequency design
    Reduces or eliminates bulky transformers resulting in lighter units for ease of handling
APC Smart-UPS 1500 LCD - UPS - 1000 Watt - 1500 VA
UPS - rack-mountable
Rack Size
1U
24.09 kg
Input Voltage
AC 230 V
Output Voltage
AC 230 V ± 5%
Power Capacity
1000 Watt / 1500 VA
Input Connectors
1 x power IEC 60320 C14
Output connectors
4 x power IEC 60320 C13 , 2 x IEC connector
Lead Acid
Batteries Qty
1
Run Time (Up To)
4.8 min at full load
RS-232, USB
43.2 cm x 66.5 cm x 44 cm
3-year warranty
Height (Rack Units)
1U
UPS Technology
Line interactive
Input Voltage
AC 230 V
Frequency Required
50/60 Hz
Input Connectors
Output Voltage
AC 230 V ± 5%
Max Electric Current
12 A
Power Capacity
1000 Watt / 1500 VA
Output Waveform
Sinewave
Surge Suppression
Surge Energy Rating
540 Joules
Circuit Protection
Circuit breaker
Quantity
1
Lead Acid
Run Time (Up To)
4.8 min at full load , 16.6 min at half load
Recharge Time
4 hour(s)
Maintenance free, sealed, leak-proof
Remote Management Interface
RS-232, USB
1 x management (RS-232) - RJ-45 , 1 x USB - 4 pin USB Type B
Expansion Slots
1 (total) / 1 (free) x SmartSlot
Power cable - external - 2.44 m , Serial cable - external , USB cable - external
Rack Mounting Kit
Included
Audible alarm, LCD display, Automatic Voltage Regulation (AVR), LED indicators, cold-start function, automatic self-test
UL 1449, RoHS, REACH
Limited warranty - 3 years , Limited warranty - batteries - 2 years
0 - 95%
Sound Emission
46 dBA
43.2 cm
66.5 cm
44 cm
24.09 kg
Shipping Width
57.5 cm
Shipping Depth
79.4 cm
Shipping Height
20 cm
Shipping Weight
29.09 kg
Type: UPS
Brand: APC
Price Range Ex VAT: 500 - 750
