Green mode bypasses unused electrical components in good power conditions to achieve very high operating efficiency without sacrificing any protection. Energy meter provides actual kilowatt hours of usage for energy conscious users. Intuitive LCD interface provides clear and accurate information with the ability to configure the UPS locally with easy to use navigation keys. Single switched outlet group may be controlled separately from the UPS for discrete reboot of hung devices, sequenced on / off and non-critical load shedding. Pure sine wave output on battery simulates utility power to provide a high degree of compatibility for active PFC (power factor corrected) servers and sensitive electronics. Cold-start capable provides temporary battery power when the utility power is out.
Cold-start capable
Provides temporary battery power when the utility power is out. -
Energy meter
Provides actual kilowatt hours of usage for energy conscious users. -
Green mode
Patent-pending operating mode that bypasses unused electrical components in good power conditions to achieve very high operating efficiency without sacrificing any protection. -
High online efficiency
Reduces utility costs, generates less heat. -
Intelligent Card Slot
Customize UPS capabilities with management cards. -
Provides clear and accurate information in multiple languages with the ability to configure the UPS locally with easy to use navigation keys. -
Predictive replace battery date
Dynamically provides the month and year when battery replacement is recommended to aide in long term maintenance planning. -
Simulates utility power to provide the highest degree of compatibility for active PFC (power factor corrected) servers and sensitive electronics. -
Single outlet group that may be controlled separately from the UPS for discrete reboot of hung devices, sequenced on/off and non-critical load shedding. -
Temperature-compensated battery charging
Prolongs battery life by regulating the charge voltage according to battery temperature.
- APC Smart-UPS 1500 LCD - UPS - 1 kW - 1500 VA
- UPS - external
- 24.1 kg
- Input Voltage
- AC 230 V
- Output Voltage
- AC 220/230/240 V ± 5%
- Power Capacity
- 1 kW / 1500 VA
- Input Connectors
- Power IEC 60320 C14
- Output connectors
- 8 x power IEC 60320 C13
- Battery
- Lead Acid
- Batteries Qty
- 1
- Run Time (Up To)
- 6.7 min at full load
- Networking
- RS-232, USB
- Black
- 17.1 cm x 43.9 cm x 21.9 cm
- 3-year warranty
- UPS - external
- Black
- UPS Technology
- Line interactive
- Input Voltage
- AC 230 V
- Input Voltage Range
- AC 160 - 286 V
- Input Voltage Range (Adjustable)
- AC 151 - 302 V
- Frequency Provided
- 47 - 53 / 57 - 63 Hz
- Frequency Required
- 50/60 Hz
- Input Connectors
- Power Output Connectors Details
- Output Voltage
- AC 220/230/240 V ± 5% - 47 - 53 / 57 - 63 Hz
- Power Capacity
- 1 kW / 1500 VA
- Output Waveform
- Sinewave
- Surge Suppression
- Surge Energy Rating
- 459 Joules
- Circuit Protection
- Circuit breaker
- Quantity
- 1
- Technology
- Lead Acid
- Run Time (Up To)
- 6.7 min at full load , 23.9 min at half load
- Recharge Time
- 3 hours
- Remote Management Interface
- RS-232, USB
- 1 x management (RS-232) , 1 x management (USB)
- Expansion Slots
- 1 (total) / 1 (free) x SmartSlot
- Cables Included
- Serial cable - external , USB cable - external , Power cable - external - 1.8 m
- Audible alarm, LCD display, cold-start function
- C-Tick, UL 1449, VDE, EN 50091-2, RoHS Exemption 7b, EN 50091-1, REACH
- Software Included
- Drivers & Utilities
- Limited warranty - 3 years , Limited warranty - batteries - 2 years
- 0 °C
- 40 °C
- 0 - 95%
- Sound Emission
- 45 dBA
- 17.1 cm
- 43.9 cm
- 21.9 cm
- 24.1 kg
- Shipping Width
- 32.8 cm
- Shipping Depth
- 59.5 cm
- Shipping Height
- 37.6 cm
- Shipping Weight
- 27.2 kg
APC Power Cord IEC 320 C13 to IEC 320 C14 | In Stock | £28.68 |
APC Replacement Battery Cartridge #7 - UPS battery - Lead Acid | In Stock | £240.34 |
APC Rack PDU, Basic, Zero U, 10A,2 | In Stock | £268.33 |
APC Temperature and Humidity Sensor | In Stock | £149.59 |
APC Power Cable (pack of 6) 1.22m | In Stock | £86.03 |
APC Dry Contact I/O SmartSlot Card | In Stock | £175.12 |
APC Power Cord Kit (6 ea) - Locking - C13 to C14 - 1.8m | In Stock | £128.98 |
APC Extended Warranty Service Pack 3 Year | In Stock | £149.99 |
APC Service Pack 1 Year Warranty Extension | In Stock | £70.60 |
APC Switched Rack PDU AP7920B Power Distribution Strip AC 200/20 | In Stock | £644.38 |
