APC Smart-UPS 1000VA LCD 230V
Quicklinx: 74C3WS00 Mfr#: SMT1000I
Trust to protect critical data and equipment from power problems by supplying clean and reliable network-grade power. In addition to legendary reliability and manageability, Smart-UPS have extremely high efficiency at low, medium and high load levels making them ideal for today's multi-core or virtualized servers that have varying load consumption. Smart-UPS series have long been considered the benchmark for all network and server UPS's. Smart-UPS feature a 16-segment LED display, extended range automatic voltage regulation (AVR), and pure sine wave output on battery.
  • Cold-start capable
    Provides temporary battery power when the utility power is out.
  • Energy meter
    Provides actual kilowatt hours of usage for energy conscious users.
  • Green mode
    Patent-pending operating mode that bypasses unused electrical components in good power conditions to achieve very high operating efficiency without sacrificing any protection.
  • High online efficiency
    Reduces utility costs, generates less heat.
  • Intelligent Card Slot
    Mini slot supports various optional management cards which provide basic or essential monitoring, management and control features for the UPS.
  • Intuitive LCD interface
    Provides clear and accurate information in multiple languages with the ability to configure the UPS locally with easy to use navigation keys.
  • Predictive replace battery date
    Dynamically provides the month and year when battery replacement is recommended to aide in long term maintenance planning.
  • Pure sine wave output on battery
    Simulates utility power to provide the highest degree of compatibility for active PFC (power factor corrected) servers and sensitive electronics.
  • Single switched outlet group
    Single outlet group that may be controlled separately from the UPS for discrete reboot of hung devices, sequenced on/off and non-critical load shedding.
  • Temperature-compensated battery charging
    Prolongs battery life by regulating the charge voltage according to battery temperature.
APC Smart-UPS 1000 LCD - UPS - 700 Watt - 1000 VA
UPS - external
18.9 kg
Input Voltage
AC 230 V
Output Voltage
AC 220/230/240 V ± 5%
Power Capacity
700 Watt / 1000 VA
Input Connectors
Power IEC 60320 C14
Output connectors
8 x power IEC 60320 C13
Lead Acid
Run Time (Up To)
6.1 min at full load
RS-232, USB
17.1 cm x 43.9 cm x 21.9 cm
3-year warranty
UPS - external
UPS Technology
Line interactive
Input Voltage
AC 230 V
Input Voltage Range
AC 160 - 286 V
Input Voltage Range (Adjustable)
AC 151 - 302 V
Frequency Provided
47 - 53 / 57 - 63 Hz
Frequency Required
50/60 Hz
Input Connectors
Power IEC 60320 C14
Output Voltage
AC 220/230/240 V ± 5% - 47 - 53 / 57 - 63 Hz
Power Capacity
700 Watt / 1000 VA
Output Waveform
Sinewave
Surge Suppression
Surge Energy Rating
459 Joules
Circuit Protection
Circuit breaker
Lead Acid
Run Time (Up To)
6.1 min at full load , 20.6 min at half load
Recharge Time
3 hours
Remote Management Interface
RS-232, USB
1 x management (RS-232) - 9 pin D-Sub (DB-9) , 1 x USB - 4 pin USB Type A
Expansion Slots
1 SmartSlot
Serial cable - external , USB cable - external , Power cable - integrated - 1.8 m
Audible alarm, emergency power off, LCD display, noise filtering
C-Tick, UL 1449, VDE, EN 50091-2, RoHS Exemption 7b, RoHS, EN 50091-1, REACH
Software Included
Drivers & Utilities
Limited warranty - 3 years , Limited warranty - batteries - 2 years
0 - 95%
Sound Emission
41 dBA
17.1 cm
43.9 cm
21.9 cm
18.9 kg
Shipping Width
32.8 cm
Shipping Depth
59.5 cm
Shipping Height
37.6 cm
Shipping Weight
22.8 kg
74C3 APC Power Cord IEC 320 C13 to IEC 320 C14 In Stock £28.68
74C3 APC Pwr Cord, 10A, 230V, C14 to UK rec In Stock £51.51
74C3 APC BackUPS+SmartUPS 1000 Battery In Stock £206.20
74C3 APC Rack PDU, Basic, Zero U, 10A,2 In Stock £263.71
74C3 APC Temperature and Humidity Sensor In Stock £150.20
74C3 APC Power Cable (pack of 6) 1.22m In Stock £87.33
74C3 APC Dry Contact I/O SmartSlot Card In Stock £175.12
74C3 APC Power Cord Kit (6 ea) - Locking - C13 to C14 - 1.8m In Stock £127.65
74C3 APC 1 Year Extended Warranty 2015-4037 In Stock £56.73
74C3 APC Service Pack 3 Year Warranty Extension In Stock £113.89
74C3 APC Basic Rack PDU AP6015A Power Distribution Unit In Stock £60.21
74C3 APC Switched Rack PDU AP7920B Power Distribution Strip AC 200/20 In Stock £644.38
