Trust to protect critical data and equipment from power problems by supplying clean and reliable network-grade power. In addition to legendary reliability and manageability, Smart-UPS have extremely high efficiency at low, medium and high load levels making them ideal for today's multi-core or virtualized servers that have varying load consumption. Smart-UPS series have long been considered the benchmark for all network and server UPS's. Smart-UPS feature a 16-segment LED display, extended range automatic voltage regulation (AVR), and pure sine wave output on battery.
Cold-start capable
Provides temporary battery power when the utility power is out. -
Energy meter
Provides actual kilowatt hours of usage for energy conscious users. -
Green mode
Patent-pending operating mode that bypasses unused electrical components in good power conditions to achieve very high operating efficiency without sacrificing any protection. -
High online efficiency
Reduces utility costs, generates less heat. -
Intelligent Card Slot
Mini slot supports various optional management cards which provide basic or essential monitoring, management and control features for the UPS. -
Intuitive LCD interface
Provides clear and accurate information in multiple languages with the ability to configure the UPS locally with easy to use navigation keys. -
Predictive replace battery date
Dynamically provides the month and year when battery replacement is recommended to aide in long term maintenance planning. -
Pure sine wave output on battery
Simulates utility power to provide the highest degree of compatibility for active PFC (power factor corrected) servers and sensitive electronics. -
Single switched outlet group
Single outlet group that may be controlled separately from the UPS for discrete reboot of hung devices, sequenced on/off and non-critical load shedding. -
Temperature-compensated battery charging
Prolongs battery life by regulating the charge voltage according to battery temperature.
- APC Smart-UPS 1000 LCD - UPS - 700 Watt - 1000 VA
- UPS - external
- 18.9 kg
- Input Voltage
- AC 230 V
- Output Voltage
- AC 220/230/240 V ± 5%
- Power Capacity
- 700 Watt / 1000 VA
- Input Connectors
- Power IEC 60320 C14
- Output connectors
- 8 x power IEC 60320 C13
- Battery
- Lead Acid
- Run Time (Up To)
- 6.1 min at full load
- Networking
- RS-232, USB
- Black
- 17.1 cm x 43.9 cm x 21.9 cm
- 3-year warranty
- UPS - external
- Black
- UPS Technology
- Line interactive
- Input Voltage
- AC 230 V
- Input Voltage Range
- AC 160 - 286 V
- Input Voltage Range (Adjustable)
- AC 151 - 302 V
- Frequency Provided
- 47 - 53 / 57 - 63 Hz
- Frequency Required
- 50/60 Hz
- Input Connectors
- Power Output Connectors Details
- Output Voltage
- AC 220/230/240 V ± 5% - 47 - 53 / 57 - 63 Hz
- Power Capacity
- Output Waveform
- Sinewave
- Surge Suppression
- Surge Energy Rating
- 459 Joules
- Circuit Protection
- Circuit breaker
- Technology
- Lead Acid
- Run Time (Up To)
- 6.1 min at full load , 20.6 min at half load
- Recharge Time
- 3 hours
- Remote Management Interface
- RS-232, USB
- 1 x management (RS-232) - 9 pin D-Sub (DB-9) , 1 x USB - 4 pin USB Type A
- Expansion Slots
- 1 SmartSlot
- Cables Included
- Serial cable - external , USB cable - external , Power cable - integrated - 1.8 m
- Audible alarm, emergency power off, LCD display, noise filtering
- C-Tick, UL 1449, VDE, EN 50091-2, RoHS Exemption 7b, RoHS, EN 50091-1, REACH
- Software Included
- Drivers & Utilities
- Limited warranty - 3 years , Limited warranty - batteries - 2 years
- 0 °C
- 40 °C
- 0 - 95%
- Sound Emission
- 41 dBA
- 17.1 cm
- 43.9 cm
- 21.9 cm
- 18.9 kg
- Shipping Width
- 32.8 cm
- Shipping Depth
- 59.5 cm
- Shipping Height
- 37.6 cm
- Shipping Weight
- 22.8 kg
APC Power Cord IEC 320 C13 to IEC 320 C14 | In Stock | £28.68 |
APC Pwr Cord, 10A, 230V, C14 to UK rec | In Stock | £51.51 |
APC BackUPS+SmartUPS 1000 Battery | In Stock | £206.20 |
APC Rack PDU, Basic, Zero U, 10A,2 | In Stock | £263.71 |
APC Temperature and Humidity Sensor | In Stock | £150.20 |
APC Power Cable (pack of 6) 1.22m | In Stock | £87.33 |
APC Dry Contact I/O SmartSlot Card | In Stock | £176.91 |
APC Power Cord Kit (6 ea) - Locking - C13 to C14 - 1.8m | In Stock | £127.65 |
APC 1 Year Extended Warranty 2015-4037 | In Stock | £56.73 |
APC Service Pack 3 Year Warranty Extension | In Stock | £113.89 |
APC Basic Rack PDU AP6015A Power Distribution Unit | In Stock | £60.21 |
APC Switched Rack PDU AP7920B Power Distribution Strip AC 200/20 | In Stock | £644.38 |
