Brand
APC Side Air Distribution Unit 2U RM 230/208 50/60HZ
Quicklinx: CX1XWS00 Mfr#: ACF202BLK
Product Type: Fan unit
£518.58 ex VAT
£622.29 inc VAT
Housing equipment with side-to-side airflow creates many challenges for IT and facility managers, particularly in regards to cooling. Because most enclosures are designed for a front to back airflow pattern, it is difficult to maintain ideal operating temperatures on side-to-side airflow equipment. The Rack Side Air Distribution Unit allows for greater security and organization by allowing racks to be placed adjacent to one another without impeding airflow.
The Rack Side Air Distribution Unit is a 2U rack mountable air distribution product for networking equipment or servers with side-to-side airflow. It pulls in conditioned air from the front of the rack and distributes it to the side air intake of the networking equipment. This extends equipment life by providing proper inlet temperatures.
This product is recommended for one or more networking products that are stacked consecutively in a rack. Rack Side Air Distribution Units may be placed above and/or below the networking equipment. Airflow pattern is user configurable via an interchangeable air turning vane.
  • Resettable circuit breakers
    Enables a quick recovery from overload events
  • Dual A-B Power Inputs
    Draws power from the UPS for power protection with dual feeds for redundancy
  • Dual fans
    Provides fault tolerance in the event of a fan failure
  • Fan control switches
    Users can turn one or both fans on and off depending on the heat load
  • Mounting rails
    Adjustable depth allows the unit to fit APC NetShelter enclosures or other 19" EIA-310-D enclosures
  • Air turning vane
    Directs air up or down the side of the rack, supplying cool air to the inlet of side-to-side airflow equipment
APC Rack Side Air Distribution 208/230V 50/60HZ - fan unit - 2U
Fan unit
Height (Rack Units)
2U
66 cm x 79 cm x 8.6 cm
15 kg
P/N: AP8702S-WWX340, AP8704S-WWX340, AP8706S-WWX340, AR3103, AR3103SP, AR3106SP, AR3357X674, AR9300SP, AR9300SP-R, AR9307SP, AR9307SP-R, NBPD0160A, NBWL0355A, NBWL0356A, SMC1500I-2UC, SMX2000LVNCUS, SMX2000LVUS, SMX3000HV-BR, SMX3000HVTUS, SMX3000LVUS, SRT1000RMXLI, SRT1000RMXLI-NC, SRT1500RMXLA-NC
Fan unit
Height (Rack Units)
2U
66 cm
79 cm
8.6 cm
15 kg
UL
Limited warranty: - 2 years
P/N: ACCS1006, ACCS1007, ACDC2513, AP5602, AP5606, AP5607, AP5616, AP7857, AP7950B, AP7957, AP8702R-NA, AP8702R-WW, AP8702S-NA, AP8702S-NAX340, AP8702S-NAX590, AP8702S-WW, AP8702S-WWX340, AP8702S-WWX590, AP8704R-NA, AP8704R-WW, AP8704S-NA, AP8704S-NAX340, AP8704S-NAX590, AP8704S-WW, AP8704S-WWX340, AP8704S-WWX590, AP8706R-NA, AP8706R-WW, AP8706S-NA, AP8706S-NAX340, AP8706S-NAX590, AP8706S-WW, AP8706S-WWX340, AP8706S-WWX591, AP8717, AR2200, AR2280, AR2400, AR2400FP1, AR2401, AR2407, AR2480, AR2487, AR2487G, AR2500, AR2507, AR2580, AR2587, AR2900, AR2901, AR3100G, AR3100SP, AR3100TAA, AR3100W, AR3100X609, AR3100X610, AR3100X617, AR3103, AR3103SP, AR3105, AR3105SP, AR3105W, AR3106SP, AR3107G, AR3107SP, AR3107X609, AR3107X610, AR3107X617, AR3140, AR3140G, AR3140W, AR3150SP, AR3150W, AR3150X609, AR3150X610, AR3150X617, AR3155, AR3155SP, AR3155W, AR3157SP, AR3157X609, AR3157X610, AR3157X617, AR3200, AR3300, AR3300G, AR3300SP, AR3300W, AR3300X609, AR3300X610, AR3300X617, AR3305, AR3305SP, AR3305W, AR3307, AR3307SP, AR3307W, AR3307X609, AR3307X610, AR3307X617, AR3340, AR3340G, AR3340W, AR3347, AR3350, AR3350SP, AR3350W, AR3350X609, AR3350X610, AR3350X617, AR3355, AR3355SP, AR3355W, AR3357, AR3357SP, AR3357X609, AR3357X610, AR3357X617, AR3357X674, AR3810, AR3812, AR3814, AR9300SP, AR9300SP-R, AR9307SP, AR9307SP-R, DLA1500RM2U, NBPD0160A, NBPD0171, NBWL0355A, NBWL0356A, SMC1000-BR, SMC15002U-BR, SMC1500I-2U, SMC1500I2U-BR, SMC1500I-2UC, SMC1500I-BR, SMT3000I2U-BR, SMX2000LV, SMX2000LVNC, SMX2000LVNCUS, SMX2000LVUS, SMX2200R2HVNC, SMX3000HV-BR, SMX3000HVT, SMX3000HVTUS, SMX3000LV, SMX3000LV2U-BR, SMX3000LVUS, SRT1000RMXLA, SRT1000RMXLA-NC, SRT1000RMXLI, SRT1000RMXLI-NC, SRT1500RMXLA, SRT1500RMXLA-NC, SU3000RMJ3U3W, SU3000RMJ3UOS3, SUA2200R3XLNETPKG, SUA3000R3XLNETPKG, SUA3000RMXL3U-BR, SUA750R2X122, SURT5000XLIX438, SURT7500XLJ-2TF4, SURTA2000RMXL2U, SURTD3000RMXLT, SURTD3000RMXLT-1TF5, SURTD5000RMXLT, SURTD5000RMXLT-1TF5
CX1X APC 1U Vertical Cable Organiser In Stock £121.52
CX1X APC - rack cable guide - 1U In Stock £51.41
CX1X APC Rack PDU, Basic, Zero U, 10A,2 In Stock £284.53
CX1X APC Rack PDU Basic Zero U 16A 208/230V In Stock £293.36
CX1X APC Rack PDU Basic Zero U 32A 230V In Stock £315.03
CX1X APC Rack PDU Basic 1U 16A 208&230V (10)C13 & (2)C19 In Stock £280.66
CX1X APC Rack PDU Basic ZeroU 16A 230V (20)C13 & (4)C19; In Stock £336.30
CX1X APC APC 17 Rack LCD Console Lite In Stock £1,052.58
CX1X APC Rack PDU 2G METERED ZEROU In Stock £678.08
CX1X APC Rack PDU 2G Switched ZeroU In Stock £1,355.17
CX1X APC Rack PDU 2G, Metered, ZeroU, 11kW, 230V, (36) C13 & (6) C19 In Stock £954.44
CX1X APC Rack PDU 2G Switched ZeroU 20A/208V 16A/230V (7) C13 & In Stock £606.92
CX1X APC Fixed Shelf - 50lbs/23kg, Black In Stock £79.79
CX1X APC Switched Rack PDU 2G Zero U Power Distribution Unit In Stock £1,537.47
CX1X APC NetShelter Zero U Accessory Mounting Bracket In Stock £70.83
CX1X APC 1U Blanking Panel Kit In Stock £33.86
CX1X APC M6 Hardware Kit Rack Screws, Nuts and Washers In Stock £54.51
CX1X APC Basic Rack PDU Zero U - Power Distribution Panel In Stock £99.78
CX1X APC Rack PDU 2G Metered ZeroU 22.0kW In Stock £1,665.21
CX1X APC Horizontal Cable Manager, 1U x 4" Deep, Single-Sided In Stock £71.39
CX1X APC Rack PDU 2G Metered ZeroU 20A/208V 16A/230V In Stock £625.18
CX1X APC Metered Rack PDU In Stock £851.57
CX1X APC NetBotz Rack Monitor 250 Environment Monitoring Device In Stock £464.08
CX1X APC Smart-UPS 1500VA RM 230V w/Network Card In Stock £1,173.11
CX1X APC Switched Rack PDU AC 208-230 V Ethernet In Stock £732.26
CX1X APC Hinged Covers for NetShelter SX 750mm Wide 42U In Stock £103.00
CX1X APC Vertical Cable Manager for NetShelter SX 750mm Wide 42U In Stock £258.99
CX1X APC Basic Rack PDU AP6015A Power Distribution Unit In Stock £60.38
CX1X APC Rack PDU 2G Metered-by-Outlet ZeroU 32A 230V (21) C13+(3)$ In Stock £1,173.46
CX1X APC Switched PDU 10A 0U C13x16 In Stock £1,145.15
CX1X APC Rack Automatic Transfer Switch AP4421 Redundant Switch In Stock £733.93
CX1X APC Switched Rack PDU AP7920B Power Distribution Strip AC 200/20 In Stock £657.54
CX1X APC Rack PDU 2G, Metered by Outlet with Switching, ZeroU In Stock £1,277.36
CX1X APC Basic PDU 1/2 Height 100-240V/20A 14xC13 In Stock £157.27
CX1X APC Rack PDU 2G, Metered by Outlet with Switching, ZeroU, 16A, 2 In Stock £1,265.93
CX1X APC Rack PDU Basic 0U/1U 100-240V/ In Stock £80.10
CX1X APC Smart-UPS 3000VA LCD RM - UPS (Rack-Mountable) AC 230 V In Stock £1,787.55
Brand: APC
Price Range Ex VAT: £500 - £750
