Your basket is empty
APC Share-UPS
APC Share-UPS
Quicklinx: DT6WS00 Mfr#: AP9207
The 8-Port Interface Expander provides a total of eight ports and can be daisy-chained to provide 15 ports. It facilitates graceful system shutdown via dependable hardwire connections and allows advanced UPS management. The unit is ideal for "server farms" or multiple operating system environments.
APC Share-UPS - remote management adapter - 8 ports
Remote management adapter
External
43.1 cm x 12.7 cm x 4.5 cm
1.6 kg
Ports Qty
8 ports
2 years warranty
Remote management adapter - 8 ports
External
Wired
8 x management - 8 , 1 x RS-232 - 9 pin D-Sub (DB-9) - 1
Mounting Kit
Included
FCC Class B certified, VCCI, C-Tick
Software Included
Drivers & Utilities, APC PowerChute plus
43.1 cm
12.7 cm
4.5 cm
1.6 kg
45 °C
0 - 95%
Max Altitude Operating
3 km
