APC Replacement Battery Cartridge
Quicklinx: 885QWS00 Mfr#: RBC34
Type: Rechargeable
£193.79 ex VAT
£232.54 inc VAT
APC sets the standard in its industry for quality, innovation and support. Its comprehensive solutions, which are designed for both home and corporate environments, improve the manageability, availability and performance of sensitive electronic, network, communications and industrial equipment of all sizes. The mission of APC is to improve the manageability, availability, and performance of information and communication systems through rapid development and delivery of innovative solutions to real customer problems.
  • Long battery life
    APC Replacement Battery Cartridge #34 is designed by APC by Schneider Electric exclusively for APC UPSs for complete compatibility with the intelligent battery management system.
  • Fully assembled for easy hot-swap installation
    APC RBCs are safe, reliable and contain a minimum number of connections saving valuable time. Because APC RBCs are hot-swappable, no network downtime is required in order to install them.
APC Replacement Battery Cartridge #34 - UPS battery - Lead Acid
UPS battery
6 kg
Lead Acid
Battery Form Factor
Internal
17.4 cm x 44 cm x 4.3 cm
1-year warranty
P/N: SUA1000RM1U, SUA750RM1U, SUA750RMI1U
UPS battery
Battery Enclosure Type
Internal
Lead Acid
Spill-proof
Limited warranty - 1 year
Min Storage Temperature
-15 °C
Max Storage Temperature
45 °C
0 - 95%
Humidity Range Storage
0 - 95%
17.4 cm
44 cm
4.3 cm
6 kg
Type: Rechargeable
Brand: APC
Price Range Ex VAT: 150 - 300
