Product
APC Replacement Battery Cartridge #44J
Quicklinx: D04ZWS00 Mfr#: RBC44J
£672.21 ex VAT
£806.65 inc VAT
APC Replacement Battery Cartridge #44J is designed by APC by Schneider Electric exclusively for APC UPSs for complete compatibility with the intelligent battery management system. APC RBCs are safe, reliable and contain a minimum number of connections saving valuable time. Because APC RBCs are hot-swappable, no network downtime is required in order to install them.
  • Long battery life
  • Fully assembled for easy hot-swap installation
APC Replacement Battery Cartridge #44J - UPS battery - Lead Acid
UPS battery
34.6 kg
Lead Acid
Battery Form Factor
Internal
Batteries Qty
1
19.7 cm x 59.7 cm x 12.2 cm
1 year warranty
Smart-UPS RT 10000VA
UPS battery
Battery Enclosure Type
Internal
Quantity
1
Lead Acid
Hot-swappable
Limited warranty - 1 year
0 - 95%
19.7 cm
59.7 cm
12.2 cm
34.6 kg
APC Smart-UPS RT 10000VA
Brand: APC
Price Range Ex VAT: 500 - 750
