APC Replacement Battery Cartridge #3
Quicklinx: D04SWS00 Mfr#: RBC3
£72.56 ex VAT
£87.07 inc VAT
In the E-world where businesses can't stop and downtime is measured in dollars, American Power Conversion (APC) provides protection against some of the leading causes of downtime, data loss and hardware damage: power problems and temperature. As a global leader in power availability solutions, APC sets the standard in its industry for quality, innovation and support. Its comprehensive power solutions, which are designed for both home and corporate environments, improve the manageability, availability and performance of sensitive electronic, network, communications and industrial equipment of all sizes.
  • Long battery life
    APC Replacement Battery Cartridge #3 is designed by APC by Schneider Electric exclusively for APC UPSs for complete compatibility with the intelligent battery management system.
  • Fully assembled for easy hot-swap installation
    APC RBCs are safe, reliable and contain a minimum number of connections saving valuable time. Because APC RBCs are hot-swappable, no network downtime is required in order to install them.
APC Replacement Battery Cartridge #3 - UPS battery - Lead Acid
UPS battery
3.7 kg
Lead Acid
Battery Form Factor
Plug-in module
9.4 cm x 15 cm x 10.2 cm
1-year warranty
P/N: BK450, BK600, BK650MC, PCNET
UPS battery
Battery Enclosure Type
Plug-in module
Lead Acid
Spill-proof
Limited warranty - 1 year
9.4 cm
15 cm
10.2 cm
3.7 kg
Brand: APC
Price Range Ex VAT: 50 - 100
