Full-featured network management interfaces that provide standards-based management via Web, SNMP, and Telnet. Allows users to access, configure, and manage rack PDUs from remote locations to save valuable time. Associated with this feature is the ability to quickly and easily upgrade the firmware via network download to installed units for future product enhancements. The aggregate current draw per rack PDU is displayed on the unit via a digital display. The local digital display helps installers avoid overloaded circuits by providing a visible warning when the current draw is close to the maximum amperage draw of the strip.
Network management capabilities
Full-featured network management interfaces that provide standards-based management via Web, SNMP, and Telnet. Allows users to access, configure, and manage rack PDUs from remote locations to save valuable time. Associated with this feature is the ability to quickly and easily upgrade the firmware via network download to installed units for future product enhancements. -
Remote individual outlet control
Remotely manage outlets so users can turn outlets off that are not in use or recycle power to locked-up equipment. -
Alarm thresholds
Define alarm thresholds in order to avoid overloaded circuits. Network and visual alarms inform the user of possible problems. -
Local current monitoring display
The aggregate current draw per rack PDU is displayed on the unit via a digital display. The local digital display helps installers avoid overloaded circuits by providing a visible warning when the current draw is close to the maximum amperage draw of the strip. -
Power delays
Allows users to configure the sequence in which power is turned on or off for each outlet. This helps avoid in-rushes at start-up, which can cause overloaded circuits and dropped loads. Sequencing also allows users to predetermine which piece of equipment is turned on first so other equipment dependant on that unit will function properly. -
Load indicator LED
Indicates overload and warning conditions based on the user-defined alarm thresholds. Alerts users of potential overloaded circuits. -
Flash upgradeable
Quickly and easily upgrade firmware via network download for future product enhancements. It eliminates the need to replace products already installed in the field when features are released. -
Single input power source
Supply power from one branch whip to multiple pieces of equipment, conveniently powering rack-mount equipment. Saves time and money during installation by using one branch whip and standard connections.
- APC Switched Rack PDU - power distribution strip
- Power distribution strip - rack-mountable
- Cord Length
- 3.66 m
- Rack Size
- 2U
- 6.3 kg
- Input Voltage
- AC 200/208/230 V
- Output Voltage
- AC 208 V
- Input Connectors
- 1 x power NEMA L6-30
- Output connectors
- 16 x power IEC 60320 C13
- Networking
- Ethernet
- Remote Management Protocol
- SNMP, Telnet, HTTP
- Black
- 44.4 cm x 25.4 cm x 8.9 cm
- 2-year warranty
- Designed For
- P/N: AR3100, SUA5000RMI5U
- Height (Rack Units)
- 2U
- Cord Length
- 3.66 m
- Black
- Input Voltage
- AC 200/208/230 V
- Input Voltage Range
- AC 200 - 240 V
- Frequency Required
- 50/60 Hz
- Input Connectors
- Power Output Connectors Details
- Output Voltage
- AC 208 V
- Max Electric Current
- 30 A
- Remote Management Interface
- Ethernet
- 1 x management
- Cables Included
- Power cable - integrated - 3.66 m
- Rack Mounting Kit
- Included
- Audible alarm, audible alarm, LED indicators
- CSA, UL, cUL, ICES-003, UL 60950, RoHS Exemption 7b, FCC Part 15 A, PSE Mark
- Software Included
- Drivers & Utilities
- Limited warranty - 2 years
- 0 °C
- 45 °C
- 0 - 95%
- 44.4 cm
- 25.4 cm
- 8.9 cm
- 6.3 kg
- Shipping Width
- 51.4 cm
- Shipping Depth
- 51.4 cm
- Shipping Height
- 14.6 cm
- Shipping Weight
- 8.4 kg
- Designed For
