Your basket is empty
APC RACK PDU SWITCHED 2U 30A 208V
Quicklinx: 7YSXWS00 Mfr#: AP7911A
Full-featured network management interfaces that provide standards-based management via Web, SNMP, and Telnet. Allows users to access, configure, and manage rack PDUs from remote locations to save valuable time. Associated with this feature is the ability to quickly and easily upgrade the firmware via network download to installed units for future product enhancements. The aggregate current draw per rack PDU is displayed on the unit via a digital display. The local digital display helps installers avoid overloaded circuits by providing a visible warning when the current draw is close to the maximum amperage draw of the strip.
APC Switched Rack PDU - power distribution strip
Power distribution strip - rack-mountable
Cord Length
3.66 m
Rack Size
2U
6.3 kg
Input Voltage
AC 200/208/230 V
Output Voltage
AC 208 V
Input Connectors
1 x power NEMA L6-30
Output connectors
16 x power IEC 60320 C13
Ethernet
Remote Management Protocol
SNMP, Telnet, HTTP
44.4 cm x 25.4 cm x 8.9 cm
2 years warranty
P/N: AR3100, SUA5000RMI5U
Height (Rack Units)
2U
Cord Length
3.66 m
Input Voltage
AC 200/208/230 V
Input Voltage Range
AC 200 - 240 V
Frequency Required
50/60 Hz
Input Connectors
Output Voltage
AC 208 V
Max Electric Current
30 A
Remote Management Interface
Ethernet
SNMP, Telnet, HTTP
1 x management
Power cable - integrated - 3.66 m
Rack Mounting Kit
Included
Audible alarm, audible alarm, LED indicators
CSA, UL, cUL, ICES-003, UL 60950, RoHS Exemption 7b, FCC Part 15 A, PSE Mark
Software Included
Drivers & Utilities
45 °C
0 - 95%
44.4 cm
25.4 cm
8.9 cm
6.3 kg
Shipping Width
51.4 cm
Shipping Depth
51.4 cm
Shipping Height
14.6 cm
Shipping Weight
8.4 kg
