The aggregate current draw per power distribution unit is displayed on the unit via a digital display. The local digital display helps installers avoid overloaded circuits by providing a visible warning when the current draw is close to the maximum amperage draw of the strip. Define alarm thresholds in order to avoid overloaded circuits. Network and visual alarms inform the user of possible problems. Load Indicator indicates overload and warning conditions based on the user-defined alarm thresholds. Alerts users of potential overloaded circuits. Includes horizontal, vertical, and tool less-mount varieties. Puts power where it is needed most - in the racks near the equipment. Supply power from one branch whip to multiple pieces of equipment, conveniently powering rack-mount equipment. Saves time and money during installation by using one branch whip and standard connections. Product family includes a variety of input and output connections to distribute 120V, 208V, or 230V power to multiple outlets. Having a variety of inputs and outputs allow users to adapt to varying power requirements. APC offers units that bring up to 14.4kW using a single branch whip.
- APC Metered Rack PDU - power distribution strip
- Power distribution strip - rack-mountable
- Rack Size
- 1U
- 1.7 kg
- Input Voltage
- AC 100 V
- Output Voltage
- AC 200 V
- Input Connectors
- 1 x power IEC 60320 C20
- Output connectors
- 8 x power IEC 60320 C13
- Networking
- Ethernet
- Remote Management Protocol
- SNMP, Telnet, HTTP
- 44.4 cm x 10.2 cm x 4.4 cm
- 2-year warranty
- Designed For
- P/N: AR3100, AR3150, SMX3000RMHV2UNC, SUA1000RMI2U, SUA2200RMXLI3U, SUA3000I, SUA750IX38
- Height (Rack Units)
- 1U
- Input Voltage
- AC 100 V
- Frequency Required
- 50/60 Hz
- Input Connectors
- Power Output Connectors Details
- Output Voltage
- AC 200 V
- Max Electric Current
- 12 A
- Remote Management Interface
- Ethernet
- 1 x management - RJ-45
- Current meter, LED indicators
- FCC Class A certified, CSA, UL, VCCI, C-Tick, GOST, cUL, VDE, UL 60950, FCC Part 15
- Limited warranty - 2 years
- -5 °C
- 45 °C
- 5 - 95%
- 44.4 cm
- 10.2 cm
- 4.4 cm
- 1.7 kg
- Shipping Width
- 47 cm
- Shipping Depth
- 33.7 cm
- Shipping Height
- 6.4 cm
- Shipping Weight
- 2.9 kg
- Designed For
