APC Rack PDU 2G  Switched  ZeroU  20A/208V  16A/230V  (7) C13 &
Quicklinx: 86DLWS00 Mfr#: AP8958
Type: PDU
Power Rating: [N/A]
£311.15 ex VAT
£373.38 inc VAT
APC Switched Rack Power Distribution Units (PDUs) enable advanced, user-customizable power control and active monitoring. Remote outlet level controls allow power on/off functionality for power recycling to remotely reboot equipment and restrict unauthorized use of individual outlets. Power sequencing delays allow users to define the order in which to power up or down attached equipment. Avoid circuit overload during power recovery and extend uptime of critical equipment by prioritizing the load shedding. Current metering provides real-time remote monitoring of connected loads. Switched Rack PDUs include real power monitoring, a temperature/humidity sensor port, locking IEC receptacles, and low profile circuit breakers. User-defined alarms warn of potential circuit overloads before critical IT failures occur. Users can access, configure, and control Switched Rack PDUs through secure Web, SNMP, or Telnet Interfaces and is complimented by APC Centralized Management platforms using InfraStruxure Central, Capacity Manager and Change Manager.
  • Network Management Capabilities
    Full-featured network management interfaces that provide standards-based management via Web, SNMP, and Telnet. Allows users to access, configure, and manage rack PDUs from remote locations to save valuable time. Associated with this feature is the ability to quickly and easily upgrade the firmware via network download to installed units for future product enhancements.
  • Remote Individual Outlet Control
    Remotely manage outlets so users can turn outlets off that are not in use (prevent overloads) or recycle power to locked-up equipment (minimize costly downtime and avoid travel time to equipment).
  • Alarm Thresholds
    Define alarm thresholds in order to avoid overloaded circuits. Network and visual alarms inform the user of possible problems.
  • Local Current Monitoring Display
    The aggregate current draw per rack PDU is displayed on the unit via a digital display. The local digital display helps installers avoid overloaded circuits by providing a visible warning when the current draw is close to the maximum amperage draw of the strip.
  • Power Delays
    Allows users to configure the sequence in which power is turned on or off for each outlet. This helps avoid in-rushes at start-up, which can cause overloaded circuits and dropped loads. Sequencing also allows users to predetermine which piece of equipment is turned on first so other equipment dependent on that unit will function properly.
  • Load indicator LED
    Indicates overload and warning conditions based on the user-defined alarm thresholds. Alerts users of potential overloaded circuits.
  • Flash Upgradeable
    Quickly and easily upgrade firmware via network download for future product enhancements. Eliminates the need to replace products already installed in the field when new features are released.
  • Integrates with StruxureWare Data Center Expert
    An IT-ready, scalable access monitoring system that collects, organizes, and distributes critical alerts, surveillance video and key information, providing a unified view of complex physical infrastructure environments from anywhere on the network.
APC Switched Rack PDU 2G Zero U - power distribution strip
Power distribution strip - rack-mountable
3.2 kg
Input Voltage
AC 200/208/230 V
Output Voltage
AC 200/208/230 V
Input Connectors
1 x power IEC 60320 C20
Output connectors
1 x power IEC 60320 C19 , 7 x power IEC 60320 C13
RS-232
Remote Management Protocol
SNMP, Telnet, HTTP
5.6 cm x 4.6 cm x 98.8 cm
P/N: AR3100, AR3150, DLT3000RMI2U, SMC1000I-2UC, SMC1500I-2UC, SMC1500IC, SMT2200RMI2UC, SMX3000RMHV2UNC, SRT1000RMXLI, SRT1000RMXLI-NC, SRT1500XLI, SRT2200RMXLI-NC, SRT2200XLI-KR, SRT3000RMXLI-NC, SRT5KRMXLIM, SRT5KRMXLW-HW, SRT6KRMXLIM, SUA5000RMI5U, SURTD2200XLIM, SURTD5000RMXLI, SYA8K8RMI
Input Voltage
AC 200/208/230 V
Input Voltage Range
AC 100 - 240 V
Frequency Required
50/60 Hz
Input Connectors
Output Voltage
AC 200/208/230 V
Max Electric Current
16 A
Remote Management Interface
RS-232
SNMP, Telnet, HTTP
1 x management
Power cable , Serial cable - external
Rack Mounting Kit
Included
LCD display
UL, cUL, EN 61000-3-2, EN55022, ICES-003, VDE, VCCI Class A ITE, EN 61000-3-3, EN55024, RoHS, FCC Part 15 A, PSE Mark, REACH
-5 °C
45 °C
5 - 95%
5.6 cm
4.6 cm
98.8 cm
3.2 kg
Shipping Width
16.5 cm
Shipping Depth
11.4 cm
Shipping Height
113 cm
Shipping Weight
4.8 kg
P/N: AR3100, AR3150, DLT3000RMI2U, SMC1000I-2UC, SMC1500I-2UC, SMC1500IC, SMT2200RMI2UC, SMX3000RMHV2UNC, SRT1000RMXLI, SRT1000RMXLI-NC, SRT1500XLI, SRT2200RMXLI-NC, SRT2200XLI-KR, SRT3000RMXLI-NC, SRT5KRMXLIM, SRT5KRMXLW-HW, SRT6KRMXLIM, SUA5000RMI5U, SURT1000XLI, SURT2000XLI, SURTD2200XLIM, SURTD5000RMXLI, SYA8K8RMI
Type: PDU
Power Rating: [N/A]
Brand: APC
Price Range Ex VAT: 300 - 500
