Your basket is empty
APC Rack PDU 2G  Switched  ZeroU  20A/208V  16A/230V  (7) C13 &
Quicklinx: 86DLWS00 Mfr#: AP8958
Type: PDU
Power Rating: [N/A]
£608.47 ex VAT
£730.16 inc VAT
APC Switched Rack Power Distribution Units (PDUs) enable advanced, user-customizable power control and active monitoring. Remote outlet level controls allow power on/off functionality for power recycling to remotely reboot equipment and restrict unauthorized use of individual outlets. Power sequencing delays allow users to define the order in which to power up or down attached equipment. Avoid circuit overload during power recovery and extend uptime of critical equipment by prioritizing the load shedding. Current metering provides real-time remote monitoring of connected loads. Switched Rack PDUs include real power monitoring, a temperature/humidity sensor port, locking IEC receptacles, and low profile circuit breakers. User-defined alarms warn of potential circuit overloads before critical IT failures occur. Users can access, configure, and control Switched Rack PDUs through secure Web, SNMP, or Telnet Interfaces and is complimented by APC Centralized Management platforms using InfraStruxure Central, Capacity Manager and Change Manager.
APC Switched Rack PDU 2G Zero U - power distribution strip
Power distribution strip - rack-mountable
3.2 kg
Input Voltage
AC 200/208/230 V
Output Voltage
AC 200/208/230 V
Input Connectors
1 x power IEC 60320 C20
Output connectors
1 x power IEC 60320 C19 , 7 x power IEC 60320 C13
RS-232
Remote Management Protocol
SNMP, Telnet, HTTP
5.6 cm x 4.6 cm x 98.8 cm
2 years warranty
P/N: AR3100, AR3150, SMX3000RMHV2UNC
Input Voltage
AC 200/208/230 V
Input Voltage Range
AC 100 - 240 V
Frequency Required
50/60 Hz
Input Connectors
Output Voltage
AC 200/208/230 V
Max Electric Current
16 A
Remote Management Interface
RS-232
SNMP, Telnet, HTTP
1 x management
Power cable , Serial cable - external
Rack Mounting Kit
Included
LCD display
UL, cUL, EN 61000-3-2, EN55022, ICES-003, VDE, VCCI Class A ITE, EN 61000-3-3, EN55024, RoHS, FCC Part 15 A, PSE Mark, REACH
-5 °C
45 °C
5 - 95%
5.6 cm
4.6 cm
98.8 cm
3.2 kg
Shipping Width
16.5 cm
Shipping Depth
11.4 cm
Shipping Height
113 cm
Shipping Weight
4.8 kg
Type: PDU
Power Rating: [N/A]
Brand: APC
Price Range Ex VAT: 500 - 750
